Vistitle gone missing
  • Vistitle gone missing
    I am using Vistitle 2.5.0 and EDIUS 7.31. Suddenly all Vistitler titles are gone across all projects. Vistitle clearly is no longer a working plug in. Anyone have experience on how to restore Vistitler's use without losing the titles?
    Hudson Valley, NY
    i7 8700K @ 3.70 Ghz/16 gb RAM
    windows 10
    284 gb SSD boot drive
    2 TB work disc
    2TB storage disc
    EDIUS 9.52.6031
    Have you checked your dongle?
      good thought...it appears to be seated OK...should the end-cap (where the tag is attached) be lighted when on?
      Hudson Valley, NY
      windows 10
      2 TB work disc
      2TB storage disc
      EDIUS 9.52.6031
        try a different USB slot
          I'll have to wait until a 2 hour download ends so I can shut down and restart with the dongle in a different slot. Another good idea. Thanks. Guess it's time to weed the shade garden :-)
          Hudson Valley, NY
          windows 10
          2 TB work disc
          2TB storage disc
          EDIUS 9.52.6031
            You don't have to reboot to move the dongle. You should be able to just unplug it and try it in a different slot
              I touched the dongle to move it. It flashed and stayed on for 5-10 secs and went off. I moved it, but no response or change. The tip is not lit.
              Hudson Valley, NY
              windows 10
              2 TB work disc
              2TB storage disc
              EDIUS 9.52.6031
                tried a third usb port..still saying device driver not recognized. I'll wait until the transfer is done and try a new slot with Vistitler dongle and a fresh boot.
                Hudson Valley, NY
                windows 10
                2 TB work disc
                2TB storage disc
                EDIUS 9.52.6031
                  Try this:
                  Uninstall Vistitle 2.5.
                  Reboot the system
                  If you haven't already done so, download the Vistitle 2.6 installer from the EU server.
                  http://www.visdownload.com/dow/VisTi...6_ENG_Full.zip
                  Now download the dongle driver from here:
                  ftp://ftp.cis-app.com/pub/hasp/Senti....9_Windows.zip
                  Now install the dongle driver and then reboot. The driver will overwrite the older driver.
                  Install Vistitle 2.6 and reboot.
                  What are your results.
                    thanks Jerry will try later.what serial number will I need to get things going.or will dongle do it all?
                    Hudson Valley, NY
                    windows 10
                    2 TB work disc
                    2TB storage disc
                    EDIUS 9.52.6031
                      You can also uninstall the Dongle manually. It should have SuperPro attached to it.
                      As long as it's on the same machine, once you get the dongle working you won't have to worry about a serial.
                        Jerry,
                        Did your step by step...the dongle seemed to install OK.
                        Vistitle started to install and never completed, instead it ended up giving me the message:
                        "Hardware Key is illegal, do you want to insert and check it again?" changing usb port with dongle then gives me message that hardware did not install.
                        Stuck. :-(
                        Hudson Valley, NY
                        windows 10
                        2 TB work disc
                        2TB storage disc
                        EDIUS 9.52.6031
                          Maybe your dongle died. You may have to contact them for a replacement.
                            go to control panel, uninstall programs and make sure the following sentinel is seen http://www.videoproductions.com.au/edius70/sentinel.png
                              Could you make sure the dongle is died ? did Its light is on or off when be pluged into the usb port of motherboard ? It should be always light on when connected with computer, and could be found in device manage of windows.
