Jumping VisTitle
  • Jumping VisTitle
    This a "why does it do this?" Has anyone else seen this?
    VT 2.6
    I make a Title "Edius 8 is really not great" Save As Ed1
    The only movement on this is from Layouter
    It is then decided to change the font and the text, open Ed1 in VT "Edius 8 is really great, not"
    Save and overwrite Ed1
    Back on the timeline the title has shifted to one side.
    Open again in VT and toggle between Text and anim mode and the title jumps even though no movement has ever been put there in VT.
    There are NO keyframes but when you click RESET in anim mode it jumps back to where it should be.
    Could it be the Southern Comfort I spilt on the keyboard? I don't recall this happening in 2.5
    It could be because of the position that has been applied to the title in Layouter. If you went back in to Vistitle and did position adjustments without putting layouter back to default, this could be the cause of the position changes.
    I'm just guessing. I'm still a little confused on what is where and when.
