E8WG + plugins: how to install?
  • E8WG + plugins: how to install?
    I am planning to install Edius 8Workgroup. I have three plugins. Do I have to install these again?
    Boris Red: no link in Edius. Seems to settle itself within Edius during installation. Install again. Correct?
    NewBlue FX, same as Boris
    Master Restauration Arts: There is some sort of link in Edius. Copy the link and everything will be fine. Correct?
    Chris
    System: Gigabyte Z390 Aorus Pro, Win10, i9 9900K, 16 Gb RAM 3200MHz, M2 SSD 250Gb for OS and Edius, M2 SSD 500Gb for projectfiles, several HDD for archieving, dual screen Benq PD2700U, GTX1070, Corsair H115i Watercooling, E9.5WG, Mercalli V4, TPMG Authoring Works 5, Davinci Resolve, Sony fdr-ax700
    copy the 3 plugins from EDIUS7/Plugins folder to EDIUS8/Plugins folder
    Uninstalling EDIUS7 does not remove the third party Plugins, so you can do that once EDIUS8 WG is installed and before you start it
      Copying over Boris Red will work. But if you go to update you will have some issues.
      I have a clean version of Edius 8 with all of my plugins installed directly....including Boris Red.
        Once you have copied the NB plugins from the E7 directory, DO NOT try and update NB till they get the E8 installers
        If you do you are just making trouble for yourself
        If they were working in E7 wait for the proper update, there seems to be a mismatch between the E7 Plug in and the update and the latest plugin is not loaded as it does not know where to go
        Barry
          In the plugin folder I can see a NewBlueFX folder, an Alpha folder and the VST folder. Plus there are some Ediusplugin files. Two of those seem te refer to Boris.
          (Boris_RED5_FL and Boris_RED5_TR) Looking at the date of the files: the two Bors files have a different date than the 20 other files. These 20 files have the date I installed Edius7.
          The VST folder is empty.
          It seems it is not as simple as copying three folders. NewBlueFX --> o.k., but the other two?
          Chris
            You only copy the non Edius plugins. However there is nothing stoping you copying the complete folder and keeing safe just incase you need them some time in the futre
