Magic Bullet QuickLooks Free
  • Magic Bullet QuickLooks Free
    I am having problems getting Magic Bullet QuickLooks Free to work in Edius 7. I did have it working once via After Effects Plug-In Bridge but can't get it to work now. How do I add this please?
    System:
    Custom build PC: EDIUS 9 Pro; ASUS PRIME H310M-A Motherboard; Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz; 16GB Corsair DDR3 RAM; NVIDIA GeForce GTX 1060 6GB; 500 Watt PSU, 1 x 250GB SATA2 Drive for System, 1 x 1TB and 1 x 2TB SATA2 drives for video footage; Pioneer BDR-207DBK 12x Internal BD-RW Burner; Windows 10 64 Bit
    UK & Ireland Cameraman and Video Editor
    From there Web page :
    Quick Looks Free works with:
    Adobe After Effects CC, CS6, CS5.5, CS5
    Adobe Premiere Pro CC, CS6, CS5.5, CS5
    Apple Final Cut Pro 6, 7
    Maybe Edius will be added later.........
    The bridge in Edius is often a hit or miss.
    Tony D.
      Well like I said in my post I did have it working via the AE Bridge in Edius 7. It's just that I can't remember how I got it there!
      System:
        Here you go. Just Add the folder location.
          Thank you.
          System:
            Oh, this issue has come up again now that I've upgraded to Edius 8 Workgroup.
            I now cannot find any path to the Adobe Plug Ins folder. I had to format my HDD and reinstall Windows 7. Don't have After Effects but do have MB Looks Free.
            System:
              How were you using it before? Was it plugging into AE? MB Looks is accessed through the AE Bridge.
              From Red Giant:
              System Requirements
                From Red Giant:
                System Requirements
                I used to have After Effects but cancelled my Creative Cloud subscription as I wasn't using it much.
                I have an old version of AE - 6.5 - that I could install. Would that then give me access to the plugins via AE Bridge in Edius??
                System:
                  Is it a CS version? If it is CS6 you're good to go.
                    Nope! Looks like I'm screwed.
                    System:
                      IIRC - you don't even need to have AE or anything installed, Bullet makes a folder which you point the bridge at - at least that's how it used to be - give it a try...
                      I just tested on my laptop that has no AE etc on it - MB installer makes the folders as shown.
                      Paul:-)
                        Paul:-)
                        Thanks Paul. Can you give the path to that folder please as I can't find the one you show anywhere
                        System:
                          That folder is under Adobe Media Core for CS6. You won't find that exact folder unless you have CS6 installed.
                          During install you are given several Adobe options. I think that is the only way to make it work.
