NewBlueFX Plugins and Edius 8
  • NewBlueFX Plugins and Edius 8
    I guess the answer to this (before I even ask the question) is that I should have waited for a while before upgrading fro v 7.50!!!
    I'm using Workgroup 8 and now my NewBlueFX plugins don't work now. Does anyone know if this is a case of reinstalling them with a different path for the plugins or is it that NewBlueFX plugins are not yet compatible with v8???
    System:
    Custom build PC: EDIUS 9 Pro; ASUS PRIME H310M-A Motherboard; Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz; 16GB Corsair DDR3 RAM; NVIDIA GeForce GTX 1060 6GB; 500 Watt PSU, 1 x 250GB SATA2 Drive for System, 1 x 1TB and 1 x 2TB SATA2 drives for video footage; Pioneer BDR-207DBK 12x Internal BD-RW Burner; Windows 10 64 Bit
    UK & Ireland Cameraman and Video Editor
    They are not compatible, not even the latest Title Pro. NB is working on it.
    My System: Edius Workgroup 9.51 & 10.0, Intel I9-9900K 3.60GHz Liquid Cooling, MSI Z390-A PRO MB, 32-GB Mem, GeForce GTX 1660 6GB GPU, BM Intensity Pro 4K Card, Win 10 Pro
      I have only tried installing Video Essentials 3 & 6 (version 3) into Edius 8 trial. I also tried Titler Pro 2
      I had to manually select the path on a fresh install but it did work.
        can you tell me what path you used please so I can have a try. Thanks.
        System:
          The trial version of Edius 8 has now expired for me, but from memory when you use the NB installer it gives you options for Edius or Edius 6.5 or Edius 7. I choose just Edius, then another window opens asking for path confirmation. This, in my case, was blank, so I just used the Browse option to select the Edius 8 plug-in folder in Program Files.
            The new versions don't have the option to steer the install.
              you can copy the newblue folder from the EDIUS7 plugin folder to the EDIUS8 plugin folder and it will work fine
              btw, I just downloaded the latest update for NB TotalFX and it lists EDIUS8 in the installation path options
                The only problem with installer is that there isn't a way to not install TP3. With TP4 out in the wild now, TP4 overwrites TP3 upon install. This gets messy in the registry. If you decide to remove TP4 the FX3 install has to be removed. Once again more mess for the registry.
                I would prefer a tick box to opt out of installing TP3.
                  As Anton said, copy the NewBlue folder from the Edius 7 Plug in folder
                  BUT WARNING! DO NOT try and update any of the NB filters at this stage, they update but do not replace the tpd file in the Plug in folder and all hell breaks loose, GPU acceleration disappears or is severely impacted or just locks the system
                  The only way out is to use a disk image as rollback does not work
                  Hope that helps someone
                  Barry
                    Hi Anton, do you have a link to where you download the newblue installer? I look all over their site but can't find it.
                      If you ever have an option of using an installer for that version or copying from an older version, I would ALWAYS use the installer (unless I knew there was a problem with it).
                        Never mind, they said it won't work with Edius 8.
                        "Dear Khoi,
                        I have looked up your account and it seems like you own some of our legacy products.
                        Only our current line of products will work with EDIUS 8.
                        Seeing as you already own some of our products, you qualify for some discounts if you are interested in upgrading to an Ultimate tier of our current products.
                        You can see those in your account page.
                        Sorry for any inconvenience this may cause you.
                        Happy editing!"
                          The newer versions work much better. I can get real time out of most of the filters using a GTX 780.
                            I have tons of their fx/filters, never use but one, maybe I will skip it this time.
                              Jerry,
                              I just installed Edius Workgroup 8 and it sees 12 cores. My system is:
                              i7-3930K CPU @ 3.2GHz
                              32GB RAM
                              Win 7Pro 64bit
                              Gforce GTX 680
                              I just purchased and installed NewBlueFx Transitions 3 Ultimate. None of them can play even a 1 second transition in real time. It will stall the buffer and creep through the frames 1 at a time in a 1920x1080 project using same size video files.
                              This doesn't seem right because all other Edius GPU transitions don't even budge the buffer and always play smoothly without stall or needing to render.
                              I tried setting the NewBlueFx to 25% preview, made sure GPU disable wasn't ticked. My system is a few years old, but I feel it should handle those transitions.
                              I will probably have to hit you up for new build advise as I started to use 4K. You were very helpful in sharing your suggestions and knowledge about best system requirements in the past and it was great advice.
                              So back to the question.... You are getting real time with most of the new NewBlueFX? Do you think my sys is not up to it?
