are trying to reinstall Robuskey after a computer problem and keep getting a error ( Fail on copying CUDA DLL ) any suggestion?
Can't install Robuskey
tdtinker
New system: Asus X99 i7 6900K 3.2GHz, 32GB DDR 4 Ram, GTX 1070 Edius 8.5
www.actvp.comTags: None
You could try to uninstall, then use Ccleaner (free version will do just fine) to clean the registry.
After that clean your %temp% file, reboot and install again.Tony D.
Originally posted by GrassValley_SL View PostAre you installing Robuskey as an admin?tdtinker
www.actvp.com
Not sure if robuskey is also affected by Antivirus software / windows defender during installation like Edius is.
Can someone confirm ?Tony D.
It should be common practice to turn any Antivirus OFF for any installation
Maybe a restart, turning the computer off, waiting 10-20 seconds with the power turned off at the power point may help
BarryWin 10HP, EDIUS WG9.4, HD Spark, Boris RED 5, VMW6, Authorworks 6, Bluff Titler, VisTitler 2.8, NEAT 3/4, Mercalli 2/4, Vitascene, Izotope RX6 Plugin, NewBlue, Trend Micro AV
Originally posted by tdtinker View Postare trying to reinstall Robuskey after a computer problem and keep getting a error ( Fail on copying CUDA DLL ) any suggestion?
it sounds like the windows version of the driver is installed instead of nvidiaAnton Strauss
Originally posted by antonsvideo View Postright click desktop, nvidia control panel, click home button to see model and driver version
it sounds like the windows version of the driver is installed instead of nvidiaLast edited by tdtinker; 07-20-2015, 04:48 PM.tdtinker
www.actvp.com
Originally posted by tdtinker View PostVersion 353.30 GTX660Ti, this looks looks the right drivers.Anton Strauss
Look at the size of the *.zip File - if it is 214 KB - you have the wrong *.zip file
from Edius Pro 8 Bonus Disk.
The correct *.zip file has a size of 11,5 MB
I had the same error and this was the solution._________________________________
Triple boot:Win10Pro/I7-5930K/GTX780/SSD-RAID/HDD-RAID/10GbE Intel X550/BMD 4K Extreme 6G/32GB RAM
Triple boot:Win10 Pro/I7-6950X/GTX1080/SSD-RAID/HDD-RAID/BMD 4K Extreme 12G/2 x 10GbE/64GB RAM
both on: 10Gbps Media sharing Network, 10Gbps NAS
Originally posted by Crespel View PostLook at the size of the *.zip File - if it is 214 KB - you have the wrong *.zip file
I had the same error and this was the solution.Anton Strauss
What is on the bonus disc?Jerry
I had the same error and this was the solution.tdtinker
www.actvp.com
what was the computer problem initially?Anton Strauss
Originally posted by antonsvideo View Postwhat was the computer problem initially?
Had to create a new profile and that's when we lost Robuskey.tdtinker
www.actvp.com
