Vistitle 2.6 now available
    this message means you have more than one EDIUS installed
    I got the same message because I have EDIUS 8 and 7.5 on the same PC, so I removed EDIUS 8 and then it installed fine in EDIUS 7.5
    note that the error complains about EDIUS 9 which is strange
    I only have Edius 7.5 installed. I have been testing Edius 8 trial on another PC.
      in that case, uninstall 2.5 and then run the 2.6 installer and report back
        Solved the issues by re-installing Vistitle 2.5, then using the 2.6 installer.
          Originally posted by John Hooper View Post
          Just tried it and got this message...any ideas? I am still using Edius 7.5.
          I got that message too and only have Edius 7.5 install.
          I switched off PC, removed the vistitle USB dongle, switched on and install 2.6 No error message this time, so I don't know what happened in the first place.
          Tony
            The Vistitle installer is looking for EDIUS 9 Plugin directory, but there is no EDIUS 9
            I got the same error
            • #21
              There is after 3 bottles of Red.
              • #22
                Perhaps I should hold off buying Edius 8, Videostar think version 9 is coming ;)
                • #23
                  I had the same message on a computer which used to have EDIUS 7 on it and did have Vistitle 2.5. I uninstalled 2.5 and just installed 2.6 and it worked ok.
                  Also on Windows 8.1 I had a message saying the installer was not certified/ratified etc, so I just had to bypass that.
                  • #24
                    I installed 2.6 on both Edius 7.5 and Edius 8 without an issue. The Edius 7.5 install was performed after uninstalling the previous version. The Edius 8 install was on a clean drive.
                    To prevent dongle issues on new installs, always go to Safenet and get the latest Sentinel drivers. Here is the latest driver:
                    http://c3.safenet-inc.com/downloads/...er%207.5.8.zip
                    Install these drivers before starting the Vistitle install.
                    I would also recommend uninstalling the previous version of Vistitle before installing 2.6. There may be problems using the installer as an update installer on an Edius 8 install where the plugin folder from Edius 7 has been pasted.
                    • #25
                      I have just received a message from Jack Chen (Videostar), who asked me to pass this on:
                      "I have lost my password for GV forum, could you help me to send the messge in there ?
                      message should be about “Please uninstall 2.5 firstly, and then use 2.6 full installer to avoid errors.”
                      • #26
                        Read my previous post.
                        • #27
                          I had read it Jerry, Jack asked me to pass his message on as he could not access the forum himself.
