Plug-in for Edius 8 question
  • Plug-in for Edius 8 question
    Can anyone tell me if these plug-ins that I have in Edius 7.5 will work in Edius 8?
    Vistitle 2.5, I understand 2.6 will be available soon to enable it to work.
    Prodad Vitascene V2
    Prodad Mercalli V2
    NewBlue Titler Pro 2
    NewBlue Video Essentials V3 (I have several, Essentials for Edius, VE 3, VE6)
    I have emailed NB and Prodad and await the answers but just wondered if anyone has tried these exsiting versions yet?
    The Edius 7 to Edius 8 upgrade is a good deal, but don't want to get it JUST because it is a good deal, only to find that I have to replace these plug-ins.
    if you install E8 on the same PC, all your plugins will work right away by copy/paste from E7 plugin folder to E8 plugin folder
    installing E8 will uninstall E7 but will not delete the plugin folder
      Thank you Anton.
      Si I don't need to de-activate the NB plug-ins first, just install the Edius 7 to Edius 8 update and everything will work OK?
      NewBlue tell me they are getting Titler Pro 4 to work with Edius 8 in a month or so, but you say thet Titler Pro 2 should work now?
        you install E8 which removes E7 but does not remove the plugins
        then you copy the plugins from the left behind E7 plugin folder to the E8 plugin folder
          Before you uninstall E7 you may also wish to make a copy of the E7 plugin Folder for future use
            I assume that this only works if you have Edius 8 installed on the PC that already has Edius 7?
            I am trying out the trial version of Edius 8 on another PC and copied the plug-ins to that PC. Edius crashes as soon as I try to open NB Tilter Pro 2. I suppose it is looking for Registry entries.
            As long as you say that I should be good to go with Edius 8 on the main PC, I will wait to try it there.
              as I mentioned, it only works if you install on the same PC
                John, I'll go down your list. This is for a clean system unless otherwise discussed.
                When Vistitle 2.6 releases it will plug directly into Edius 8.
                Prodad Vitascene V2
                Vitascene has an installer for Edius 8 and CC 2015
                Prodad Mercalli V2
                I tested Mecalli V4 and it has an Edius 8 and CC 2015 installer. Does the V2 installer allow you to point the install to a different folder? If so, you could install it. I don't know if they will do an installer for V2.
                The New Blue items will have to have new installers. They don't allow you to point the install where it needs to go.
