Edius and plugins
  • Edius and plugins
    Hello all I have recently purchased a sony action camera fdr v1000x ,
    just a few questions i see the footage in 4k in this action cam has terrible fish eye due to 170 deg lens not such a problem in 1080 which only shows 120 deg angle due to image stabilization cropping.
    Will pro dad plugin work with edius 7 and does this work well for fisheye i dont have the camera yet so cant download a trial to try footage to work on.
    Also i assume edius supports sonys XAVC S codec .
    If you are talking about Defishr, it's a stand alone program.
    Here's a thread that might be of some use to you.
    http://forum.grassvalley.com/forum/s...hlight=fisheye
      I have the FDR V1000X and correct it's distortion using HitFilms 3 Pro. Works very well and quickly. ProDAD's DeFishr works quite well (has no setting for the Sony FDR V1000X yet) but other presets work well with a little tweeking. As Jerry mentioned, DeFishr is a standalone program as is HitFilms.
      i7 3930K, Win 10 pro 64 Bit.
      RAM 32 GB.
      ASUS P9X79-Deluxe.
      PS Thermaltake 1kW.
      Graphics Gigabyte GTX1660 OC.
        Just another sugestion
        NewBlue Essentials has a "Lens Correction" Filter and very easy to use
        and is inside Edius why not try the Trial and see what you think
        Regards Barry
          Ok thanks for the replies ,ill look into these options if my cam arrives just noticed the ebay seller has no feedback .so could be doubtful .
            The downside to the NB plugins is that they are all 8 bit.
              which means what exactly in 8 bit slow to render effect ?
              sorry for not being tech orientated
                The new blue fx looks nice but the whole package costs 3 times as much as edius although i see you can purchase individual elements .
                  Ok tried both blue fx and pro dad think i prefer the pro dad results although not as usefull a plugin as the fx ones as it is like a stand alone program and only outputs mp4(mpeg-4) ,but the fx is really hard to apply to look better than the original ,might just be me though .and pro dad has dedicated defish for the sony cam in steady shot and normal it even played 4k footage.
                  Thanks for the tips anyway
                    Head over to this site , there was a promo on ProDAD ,just follow the instructions and you will get http://www.mostiwant.com/prodrenalin...serial-number/
                      For free, it's ok. The fish eye correction wasn't any better than NB. If there isn't a camera profile, good luck. Color correction was adequate at best. The presets were mostly weird color effects. As far as free goes, if you use a GO Pro, the Go Pro Studio software is free as well, with a lot more options.
                      Then you have to export out and import into your NLE from both of these.
                      As I said, for free...it's ok.
