NeatVideo 4
  • NeatVideo 4
    Today we have a new version NeatVideo .4 for Edius Pro 7, Edius Pro 6.5 and Neo 3.5 (64bit and 32bit) working with Windows 8.x, 7, Vista and XP.
    http://www.neatvideo.com/
    MPPais
    V4 upgrade purchased.
    Thanks for supporting Edius!
    <edit>
    Frame Size: 1920x1080 progressive
    Temporal Filter: Enabled
    Radius: 2 frames
    Dust and Scratches: Disabled
    Neat Video 4.0.0 Pro plug-in for Edius
    Detecting the best combination of performance settings:
    running the test data set on up to 24 CPU cores and on up to 1 GPU
    GeForce GTX TITAN: 5567 MB currently available (6144 MB total), using up to 100%
    CPU only (1 core): 0.935 frames/sec
    CPU only (2 cores): 1.9 frames/sec
    CPU only (3 cores): 2.71 frames/sec
    CPU only (4 cores): 3.47 frames/sec
    CPU only (5 cores): 4 frames/sec
    CPU only (6 cores): 4 frames/sec
    CPU only (7 cores): 4.17 frames/sec
    CPU only (8 cores): 4 frames/sec
    CPU only (9 cores): 3.83 frames/sec
    CPU only (10 cores): 3.73 frames/sec
    CPU only (11 cores): 3.6 frames/sec
    CPU only (12 cores): 3.41 frames/sec
    CPU only (13 cores): 4.76 frames/sec
    CPU only (14 cores): 4.67 frames/sec
    CPU only (15 cores): 5.26 frames/sec
    CPU only (16 cores): 4.76 frames/sec
    CPU only (17 cores): 4.67 frames/sec
    CPU only (18 cores): 4.39 frames/sec
    CPU only (19 cores): 4.85 frames/sec
    CPU only (20 cores): 4.57 frames/sec
    CPU only (21 cores): 4.35 frames/sec
    CPU only (22 cores): 4.17 frames/sec
    CPU only (23 cores): 4.15 frames/sec
    CPU only (24 cores): 4.03 frames/sec
    GPU only (GeForce GTX TITAN): 6.37 frames/sec
    CPU (1 core) and GPU (GeForce GTX TITAN): 7.75 frames/sec
    CPU (2 cores) and GPU (GeForce GTX TITAN): 7.87 frames/sec
    CPU (3 cores) and GPU (GeForce GTX TITAN): 9.26 frames/sec
    CPU (4 cores) and GPU (GeForce GTX TITAN): 9.8 frames/sec
    CPU (5 cores) and GPU (GeForce GTX TITAN): 10 frames/sec
    CPU (6 cores) and GPU (GeForce GTX TITAN): 9.8 frames/sec
    CPU (7 cores) and GPU (GeForce GTX TITAN): 9.8 frames/sec
    CPU (8 cores) and GPU (GeForce GTX TITAN): 9.43 frames/sec
    CPU (9 cores) and GPU (GeForce GTX TITAN): 9.35 frames/sec
    CPU (10 cores) and GPU (GeForce GTX TITAN): 9.26 frames/sec
    CPU (11 cores) and GPU (GeForce GTX TITAN): 9.17 frames/sec
    CPU (12 cores) and GPU (GeForce GTX TITAN): 9.17 frames/sec
    CPU (13 cores) and GPU (GeForce GTX TITAN): 9.43 frames/sec
    CPU (14 cores) and GPU (GeForce GTX TITAN): 9.62 frames/sec
    CPU (15 cores) and GPU (GeForce GTX TITAN): 9.09 frames/sec
    CPU (16 cores) and GPU (GeForce GTX TITAN): 9.62 frames/sec
    CPU (17 cores) and GPU (GeForce GTX TITAN): 9.09 frames/sec
    CPU (18 cores) and GPU (GeForce GTX TITAN): 9.09 frames/sec
    CPU (19 cores) and GPU (GeForce GTX TITAN): 8.85 frames/sec
    CPU (20 cores) and GPU (GeForce GTX TITAN): 8.4 frames/sec
    CPU (21 cores) and GPU (GeForce GTX TITAN): 8.2 frames/sec
    CPU (22 cores) and GPU (GeForce GTX TITAN): 8.55 frames/sec
    CPU (23 cores) and GPU (GeForce GTX TITAN): 8.33 frames/sec
    CPU (24 cores) and GPU (GeForce GTX TITAN): 8 frames/sec
    Best combination: CPU (5 cores) and GPU (GeForce GTX TITAN)
    Good - Cheap - Fast. You get to pick two!
    <edit>
    v3 results
    Frame: 1920x1080 progressive, Radius: 1 frame
    Running the test data set on up to 24 CPU cores and on up to 1 GPU
    CPU only (1 core): 1.34 frames/sec
    CPU only (2 cores): 2.71 frames/sec
    CPU only (3 cores): 3.85 frames/sec
    CPU only (4 cores): 4.88 frames/sec
    CPU only (5 cores): 5.56 frames/sec
    CPU only (6 cores): 5.88 frames/sec
    CPU only (7 cores): 5.56 frames/sec
    CPU only (8 cores): 5.29 frames/sec
    CPU only (9 cores): 5.13 frames/sec
    CPU only (10 cores): 4.76 frames/sec
    CPU only (11 cores): 4.59 frames/sec
    CPU only (12 cores): 5.95 frames/sec
    CPU only (13 cores): 6.02 frames/sec
    CPU only (14 cores): 7.09 frames/sec
    CPU only (15 cores): 7.09 frames/sec
    CPU only (16 cores): 6.99 frames/sec
    CPU only (17 cores): 7.25 frames/sec
    CPU only (18 cores): 6.71 frames/sec
    CPU only (19 cores): 6.21 frames/sec
    CPU only (20 cores): 5.92 frames/sec
    CPU only (21 cores): 5.59 frames/sec
    CPU only (22 cores): 5.18 frames/sec
    CPU only (23 cores): 4.98 frames/sec
    CPU only (24 cores): 4.81 frames/sec
    GPU only (GeForce GTX TITAN): 9.8 frames/sec
    CPU (1 core) and GPU (GeForce GTX TITAN): 11.1 frames/sec
    CPU (2 cores) and GPU (GeForce GTX TITAN): 10.3 frames/sec
    CPU (3 cores) and GPU (GeForce GTX TITAN): 11.2 frames/sec
    CPU (4 cores) and GPU (GeForce GTX TITAN): 12.5 frames/sec
    CPU (5 cores) and GPU (GeForce GTX TITAN): 13.9 frames/sec
    CPU (6 cores) and GPU (GeForce GTX TITAN): 13.7 frames/sec
    CPU (7 cores) and GPU (GeForce GTX TITAN): 13.7 frames/sec
    CPU (8 cores) and GPU (GeForce GTX TITAN): 13.2 frames/sec
    CPU (9 cores) and GPU (GeForce GTX TITAN): 12.8 frames/sec
    CPU (10 cores) and GPU (GeForce GTX TITAN): 12.3 frames/sec
    CPU (11 cores) and GPU (GeForce GTX TITAN): 12 frames/sec
    CPU (12 cores) and GPU (GeForce GTX TITAN): 12.2 frames/sec
    CPU (13 cores) and GPU (GeForce GTX TITAN): 12.3 frames/sec
    CPU (14 cores) and GPU (GeForce GTX TITAN): 11.8 frames/sec
    CPU (15 cores) and GPU (GeForce GTX TITAN): 12.5 frames/sec
    CPU (16 cores) and GPU (GeForce GTX TITAN): 12.2 frames/sec
    CPU (17 cores) and GPU (GeForce GTX TITAN): 12.2 frames/sec
    CPU (18 cores) and GPU (GeForce GTX TITAN): 11.6 frames/sec
    CPU (19 cores) and GPU (GeForce GTX TITAN): 11.6 frames/sec
    CPU (20 cores) and GPU (GeForce GTX TITAN): 10.9 frames/sec
    CPU (21 cores) and GPU (GeForce GTX TITAN): 10.5 frames/sec
    CPU (22 cores) and GPU (GeForce GTX TITAN): 10.1 frames/sec
    CPU (23 cores) and GPU (GeForce GTX TITAN): 10.3 frames/sec
    CPU (24 cores) and GPU (GeForce GTX TITAN): 9.9 frames/sec
      Rusty: Do you recall how the same test did with the previous version of Neat Video?
      Is the new version any faster? better?
        Here is part of the .pdf on the new release.
        The heart and soul of Neat Video — its state-of-the-art noise reduction algorithms — have been greatly enhanced in version 4. In particular, the quality of filtration is now much higher in difficult and special conditions such as scenes with changing luminance or chrominance (fade in/out, camera auto gain control) and clips with repeated frames produced in Slow Shutter or similar shooting modes.
        A new dedicated Dust and Scratches filter reduces defects affecting individual frames in old films, damaged VHS tapes, air-transmitted analog TV signal, etc. Another important addition is an Artifact Removal filter, which deals with several types of digital artifacts typically created by in-camera noise reduction and compression or introduced during post-processing.
        The Sharpening and Edge Smoothing functions in Neat Video v4 produce better results too.
        Years of Neat Video team’s experience combined with very helpful feedback from Neat Video users have resulted innumerous workflow optimizations and interface improvements in Neat Video v4. These include the new set of filter
        settings restructured for better navigation and flexibility, improved and optimized preview showing the combined effect of all used filters, variants of filtration to compare previews produced with different filter settings, a new set of filter presets to solve typical noise reduction tasks and many other improvements.
          Just ran a quick install test on my system:
          ASRock Z97 Extreme6 w/ i7-4790, 32 GB ram, GTX-770. not OC-ed, with E7.5.
          Neat v4.0 Optimize for 1080i, radius=2, came up with 5 cores + GPU at 11.2 fps as best.
          Neat v3.4 reported the same optimize result.
          Have not had a chance to compare results.
            after testing Neatvideo4, I discovered the following:
            any filter that is above neatvideo in the info palette is ignored and not processed, so be sure to drag all filters below neatvideo in order for them to be effective
              Neat Video needs to be the first one in the effects Pallet.
              This was also best practice for previous versions.
                Ive also found with 3.6 to keep Neat at the top for the reasons Anton mentioned.
                John Sirb
                Lake Breeze Video Lorain,OH
                SYS 1: Edius 9, Vistitle 2.5, Boris Red,Neat Video, Gigabyte Z170x G5, I7 6700K 4.0Mz Skylake, G.SKILL Ripjaws X Series 8GB x2, NVIDIA QUARTO 2000
                JVC HM-100,JVC HM-700, JVC HM-600, Canon 80D
                  As Steve mentioned, Neat should always be on top.
                    The Neat help info clearly states that NEAT should be first above layouter too.
                    Ron Evans
                    Ron Evans
                      We have a manual for Edius: http://www.neatvideo.com/files4/NVEDUG.pdf
                      This manual has a recomendation:
                      Important: Check the order of effects in the Information tab. Make sure Neat Video v4 goes first there
                      and stays above Layouter as shown in the image above. Manually drag Neat Video v4 to the top there if necessary.
                      MPPais
                        Better, probably. More testing required.
                        Faster, nope.
                        See previous post update.
                          For those who either find it complicated and/or annoying to log in just to see the upgrade price from v3 Pro to v4 Pro here it is:
                          49.90 Dollar plus tax
                          47.90 Euro plus tax
