The end of Cuda encoding in Tmpg
  • The end of Cuda encoding in Tmpg
    I use Tmgp video mastering works 5 for most of my encoding needs. I received an E-mail about the release of version 6 and it says no more Cuda assisted encoding. Apparently they will use new hardware encoding available on newer Nvidia cards.
    Anyone care to explain how this will play out for us Edius users that rely on TmPG for our encoding needs?
    Also gone are 32-bit OS, DV, and HDV capture support?
    Maybe the answer is to have both v5 and v6 installed and use which ever is appropriate to the task at hand.
      Keep on using version 5 and you have what you always had :)
      If proven to be better (and faster) then upgrade software and hardware and never look back......
      If I'm not wrong you can keep both software versions running on the same system, as long as you don't upgrade, then you'll lose the previous version but enjoy discount.
      Tony D.
        That DV and HDV support are gone is a tad some for some, regarding 32 bit OS support, MS should have done away with that when releasing windows 7.......
        Luckily more and more software is 64 bit only, so it's gonna face out anyhow :)
        Tony D.
          Cuda never improved speed or quality, so no loss for me
            Speed did have marginal improvements but only in single digit percentile, one extra drop of beer in a small glass :)
            Tony D.
              MW6 will support H.265 encoding with the GTX 970 and GTX 980. MW6 has been out in Japan for several months.
              CUDA encoding was good if you didn't have any other forms of acceleration, i.e. Spur engine, lots of cores, or QS. I tested it in MW5 but never used it for main outputs.
              If you have a video that utilizes the MW6 software features, you'really good to go.
                There is only one option to be able to use MW5 with MW6. There is a price category for that. Go to the site to read the pricing structure:
                http://tmpgenc.pegasys-inc.com/en/sh...l#tabSelector1
                  Can a upgrade to AW6 be far behind?
                    I have TMPGenc V4 that I used most of the time but also have V5 so will upgrade 5 and keep 4 I think as I don't really use V5. Reasonable cost. On my systems CUDA was never used anyway so no loss and on my present system I only have the Intel GPU.
                    Ron Evans
                    Ron Evans
                      I'm using the trial and if you are planning on using H.265, it is painfully slow. It might be a bit faster with a GTX 970 or GTX 980. Or when Quicksync becomes capable.
