Just wondering if anyone has SoundSoap 4 and what you think of it?
Thanks,
Tim
MAIN SYSTEM:Asus P8Z68 DELUXE, Core i-7 2600k @ 4.6Mhz (stable), 32gb DDR3 1600 (1833 oc) Vengence RAM, 512gb SSD (OS and Apps Only), 256gb SSD Scratch Disk, 2TB Caviar Black SATA3 RAID Video Drive, Nvidia GTX 970 (oc'd), Windows 7 PRO 64-bit, all in a customized HAF-X case ... complete with holographic logo. [Air cooled into the low teens idle, 49c under heavy sustained oc'd load.] Dual 19" displays with 32" video monitor. ShuttlePRO.
Soundsoap was problematic in EDIUS I don't know if anything has changed. At the time the same issues were present in most of the hosts (applications).
I have not tried Soundsoap after purchasing a full version a long time ago because it was not worth the headache.
Maybe you can try and tell us if it has improved. :)
I own SoundSoap 4. I find it easy to use and get good results with, but it has an annoying audio delay bug.
There was a discussion on the Soundness LLC forums where I provided a better workaround (using the Audio Offset feature in Edius rather than unlinking the audio and video, and manually shifting the audio) -- for reasons I cannot understand that information no longer appears on their forum.
If it wasn't for the audio delay bug, I would not hesitate the recommend the program. When SoundSoap came bundled with Edius the bug didn't exist, now it does and Soundness blames Edius for it. Other VSTs don't have the issue, so I suspect the fault lies with Soundness, but they don't seem interested in fixing it.
if you want one with 0.000% delay, use wavearts master restoration, I use it a lot, very easy to remove airconditioner etc. noise with no change in voice quality
Thank you everyone for the replies. Sorry to hear about the delay issue. It might still be worth it for $50 ... with a workaround. *Thanks Thoff) I'll check out the other as well, Anton.
-Tim
