NewBlue titler unistall problem
  • NewBlue titler unistall problem
    Hi, I used NewBlue titler and now use Heroglyph. I have just unistalled NewBlue titler but I already see it on the Edius titler options:
    https://dl.dropboxusercontent.com/u/...e%20titler.jpg
    I have installed NewBlue titler again and unistalled again but I always get that writing.
    How can I delete that writing?
    Thnaks
    A lonesome traveler looking for lost tribes around the world: https://www.youtube.com/c/ExploringWorldA/videos
    CPU: Intel i9 7940X
    SSD Drive:
    Did you de-activate the NewBlue Titler first, then use the uninstaller in NewBlue?
    When uninstalled did you reboot the PC?
      I don't have de-activate the NewBlue Titler first. How can I do it?
      I have used unistaller in NewBlue. But I have niticed I had some NewBlue files even on Programs x86. I have deleted them manually.
      Yes
      CPU: Intel i9 7940X
      SSD Drive:
        Also check the common files directory but be careful if its installed in more than one NLE
        If you are familiar with registry editor you may find many many references to the titler
          In common files folder I have "ManagerGL64.dll" only. What a pity! I will find the titler on Regedit.
          CPU: Intel i9 7940X
          SSD Drive:
            Thnaks
            just delete it from the plugins folder in EDIUS (program files/grass valley...)
            then start EDIUS and it will be gone
              It is right! You know well Edius. ;) Thanks
              CPU: Intel i9 7940X
              SSD Drive:
