VisTitle Library moving
  • VisTitle Library moving
    Hi folks,
    i want to moving the library from drive c: to another drive.
    Has anybody an idea, pls.?
    Thx. for yours support in advance.
    regards
    klaus
    Probably the best way would be to uninstall it then when you re-install change the install location
      I've found that the best installation is to the system drive. I tried it a while back and it just didn't work properly.
        Hi, and thx for your quick response.
        @Adbear: On my system a re-install has no effect, Only VisTitle self was installed on the new drive. The Library was installed again at the old location.
        @Jerry: Okay, it sounds it is better to forget my idea, or?
        Thx. again.
        Kindly regards
        Klaus
