AE FEC plugins list tested
  • AE FEC plugins list tested
    AE Plugins in Edius;- (Basic primary function only tested, not tracker or pre-process source)
    Folder: FEC Blur & Sharpen
    Blur OK
    Channel Blur OK
    Directional Blur + Direction OK
    Sharpen OK
    Soften NO
    Spin Blur OK (but no Spin Fall off)
    Spiral Blur OK
    Unsharp Mask OK
    Vector Blur OK
    Zoom Blur OK
    Folder: FEC Colour Correction
    Brightness Contrast OK
    Colour Balance HLS OK
    Colour Balance RGB OK
    Colour Offset OK + modes OK
    Gamma-Pedestal-Gain OK
    Invert OK
    Replace Colour OK
    Threshold OK
    Threshold RGB OK
    Tint OK
    Toner OK
    Folder: FEC Distort
    Bend It OK
    Bender OK
    Bulge OK
    EZ Lazy Waves OK
    EZ Ripples OK
    Flo Motion OK
    Griddler OK
    Lens OK
    Power Pin OK (RT playback better than NBlue)
    Rectangular Scale Wipe OK
    Ripple Pulse NO
    Slant OK but Floor X doesn’t work
    Slant Matte OK but ditto
    Smear OK
    Spherize OK
    Split OK
    Split 2 Not supported on this Host
    Tiler OK except softness control
    Twirl OK
    Water Waves OK
    Folder: FEC Edges
    Burn Edges – Not Convinced it works
    Gradient Blur OK
    Power Ramp OK
    Sparkle Edges Works but not sure about edge bit not like Vitascene
    Spot Blur OK
    Spot Feather (Vignette) OK
    Spot Frame OK (Highlighter frame)
    Spot Tatter OK (Tattered edge Vignette)
    Spot Turbulance OK (Rippling picture)
    Wiggle Edges Not sure just adds spots to screen
    Folder: FEC Light
    Light Blast OK
    Light Burst OK
    Light Rays OK
    Light Sweep OK
    Light Tornado OK
    Light Whirl OK
    Spotlight OK
    Folder: FEC Particle
    Ball Action NO
    Bubbles NO
    Drizzle NO
    Hair OK but can’t see a use
    Mr Mercury NO
    Particle Systems II NO
    Particle World NO
    Pixel Polly NO
    Rain NO
    Star Burst NO
    Folder: FEC Perspective
    Advanced 3D OK
    Cylinder Including light position OK
    Page Turn OK
    Simple Shadow OK but can’t see use might work on a Graphical object
    Sphere OK
    Super Shadow OK as simple shadow above
    Folder: FEC Stylise
    3D Relief OK
    Blobbyise OK
    Burn Film OK
    Emboss OK
    Fractal OK
    Glass OK
    Glow OK
    Glue Gun NO black screen
    Kaleida OK
    Lens Star OK
    Mr Smoothie OK
    Repetile OK
    Scatteriize OK
    Video Fragment OK
    Folder: FEC Time
    Force Motion Blur Not supported in host
    Time Blend OK
    Time Blend FX NO
    Wide Time NO
    Folder: FEC Transitions
    Blur Dissolve OK
    Glass Wipe OK
    Grid Wipe OK
    Griddler Wipe OK
    Image Wipe OK
    Jaws OK
    Lens Wipe OK
    Light Wipe OK
    Pin Wipe OK
    RGB Dissolve NO
    Radial Scale Wipe
    Radial Scale Wipe OK
    Rain Wipe NO
    Scale Wipe OK
    Slant Wipe OK
    Spherise Wipe OK
    Super dissolve just brightens up centre and goes away
    Twister OK
    I will move on to the others including BCC 8 & 9, Sapphire etc, when I have time, I hope this is of some use.
    BCC are not supported via AE Bridge
    I have tried some and i got an unsupported host message from BCC
    There were also loads off Edius crashes
      AE Plugins Testing Continued
      The caveat is that this applies to my system 4 set up as in the signature, others may have different results with a different hardware set up.
      The Attached Jpeg shows the AE plugins folder list, excluding NewBlue and Vistitle which live in the GV Plug-ins folder.
      Generally filters that have a mask or shape in which to apply the effect, do not show that shape, or the effect is not defined by the shape.
      Some of the light rays ones in GenArts Sapphire memory leak into GPU2 memory despite Nvidia control panel being configured to GPU1 only for Cuda and OpenGL
      Ones not listed below in the Plug-ins packs generally work, and I was pleasantly surprised to see that BCC9 generators did produce rain and snow.
      In the folders the following were removed as causing issues or not working at all.
      BCC9
      3WayColorGrade not supported in host.
      Beat Reactor
      Bulge not supported in host
      GLImage Shatter
      Ripple
      RippleDissolve
      RippleDissolve
      RippleDissolvePrTr
      Scaterize
      Turbulence
      trwirl
      Wave
      Re:Vision DeNoise These Cause Edius to go not responding.
      DeNoise
      DeNoise_64
      DENoiseaverage
      DeNoiseAverage_64
      FEC
      BallAction
      Bubbles
      BurnEdges
      Drizzle
      ForceMotionBlur
      GlueGun
      MrMercury
      ParticleSystemsII
      ParticleWorld
      PixelPolly
      Rain
      RainWipe
      RGBDissolve
      RipplePulse
      Soften
      Split2
      StarBurst
      SuperDissolve
      TimeBlend
      TimeBlendFX
      WideTime
      Fields Kit3 (these don't work but control panels do appear ok)
      Deinterlacer
      Pulldown
      Reinterlacer (would be useful for 25p to 50i)
      Knoll Light Factory
      All
      Magic Bullet Frames
      BroadcastSpec
      FramesPlus
      Letterboxer
      Opticals
      MB Looks
      Looks3_64 (This crashes on exit from Edius and causes file open issues and Edius disappearing instantly) 2.1.3 is recommended version, this is v2.5.3
      Red Giant Text Anarchy
      Path Distort
      REFlex
      REFlexMorph
      REFlexMotionMorph
      REFlexWarp
      Sapphire Blur+Sharpen
      BlurMotionCurves - Controls very sluggish
      BlurMotion
      Convolve
      ConvolveComp GPU error
      Deband
      DefocusPrism
      EdgeAwareBlur
      Median - Controls very sluggish
      Sapphire Time
      All (as per GV not compatible list)
      Sapphire Transitions
      CardFlip
      DissolveDistort
      DissolveEdgeRays
      DissolveFlashbulbs
      DissolveGlare
      DissolveRays
      Smooth kit part
      SKDirectionalAE
      SKDirSplines
      SmoothKit3
      All
      Twixtor6AE
      All
      Regards
        For me Looks 2.5 is crash on exit free
        2.52 and 2.53 cause crash on exit
        Some get 2.53 to work
          Yes John it seems less than clear cut in terms of crashing or not, depending on hardware configurations and other software installed.
            As an aside, I'd like to mention that many of the FEC effects (and transitions) are available directly to Edius through Boris Red.
            I have taken 2 screen shots.
            Regards
            Douglas
            Creator of Video Tutorials for mere mortals at https://www.gaijin-eyes.com
            Main System: EDIUS WG 9, Asustek Intel Z370, i7-8700K @ 3.70GHz, 32GB RAM, GTX-1080Ti, BMD Intensity Pro 4K, Windows 10 Pro
              ...and in both cases they have no real time performance..... in Edius.
                That is very true, Jerry
                Any effects done in Boris Red need to be rendered.
                I was just pointing out that there are other places that you can access the FEC Effects from, without having to round-trip.
                I seldom use the FEC Effects, but I did a couple of tests just now, and I did not have any problems with crashes.............. but I did need to render
                As they say, "Everybody wants to get to Heaven - but nobody wants to die"
                Regards
                Douglas
                  BCC9 Rain or Snow is real time in Edius.
