EDIUS crashes after NewBluefx Titler Pro 2 installation
  • EDIUS crashes after NewBluefx Titler Pro 2 installation
    Hi every one,
    After installing the latest version of Titler Pro 2, EDIUS crashes showing the messages attached.
    I also tried to open it as standalone and I also got the runtime error attached.
    I unistalled both EDIUS and Titler pro 2.0 but the problem is still remaining.
    Any ideas?
    Thanks,
    Kostas
    Kostas Κ.
    HP Z800 Workstation: 2x Intel Xeon X5660 (12 cores - 24 nodes), 24GB DDR3 ECC, nVidia GTX 960 2GB, Win 10, SSD as Boot drive, RAID 0 for video editing, QNAP NAS for Storage, 2x Gigabit Ethernet connection
    I thought Titler Pro 3 is the latest?
    also it looks like you are you using a 4:3 desktop resolution?
      What graphics card are you using and how old are the drivers?
        Titler 3 comes up as Titler 2 in the program file folder listing - it's very confusing.
        Tiler 2 will crash Edius that was my experience, it needs to be the latest one which is ok.
        Titler Pro 2.0 for Windows folder should have a dll file Titler20.dll and that should report it is version 3.
        Titler Pro folder needs to be present as well.
        Titler20Plugin7.tpi can be removed from the Edius Plugins folder > NewBlueFX > Titler for Windows temporarily, to get you going and it can parked on the desktop.
        It does not report a version.
        The other NewBlue Effects can set whether to render with the GPU or not in the i tab at the top. It might be good to try Titler again with the GPU turned off in the other effects which can be set to just this effect or all effects, I suggest set to all to retry Titler Pro, but you will have to remove Titler to try that by parking it on the desktop.
        Edius Tests all the plugins for compatability at start up.
          That ISL view is remote desktop software Anton, hence the 4 by 3.
            Hi guys,
            The problem was the old VGA driver version.
            Updating the ATI Radeon 4800HD with the latest drivers version, everything seems to work fine now.
            Thanks,
            Kostas
            Kostas Κ.
