What's a good audio compression plug in for 6.5?
Audio compressor plug in
Originally posted by JoKiT View PostWhat's a good audio compression plug in for 6.5?Tony D.
Izotope Ozone 5 Maximiser has a preset for TV levels, you can use up to -3dB for on line files.
It doesn't sound "pumpy" (loud to quiet) and its nice and clean and undistorted.
The max output (limiter) level is set by the right hand fader in the dialogue window and the left hand slider the drive level into the compressor.
MDA dynamics is quite good although I use that one more on a music bed at - 27dB to keep the music bed constant level so it doesn't intrude on dialogue.
There is Voxengo Elephant and Deft Compressor as well as T-Sledge but only any good if 64Bit compatible ones if you move to Edius 7.
A trick I discovered was to get the audio balance roughly correct in a sequence, create a master sequence and drop in the sequence you have just been working on and add the compressor to there rather than to the individual tracks and it is similar then to the Adobe timeline Master Track. That tends to get rid of those little problems like a loud sound effect over the start of some music going into the red whilst they are both mixing over (additative mix).
You should then watch the output on the loudness meter built in to Edius if for Broadcast as your final quality control.
MikeSys4: Edius9/XWG ASUS Z10PE-D16WS MB 2xE5-2696 Xeon 72 cores. 16TB RAID0 64G RAM RTX3090Ti. Samsung 55" QLED 1500 NIT HDR 4K TV. Storm3G Elite/Decklink 4K 12G HDR. Yamaha RX-A870 A/V 7.1 audio. Sys1-3 Edius 8.5 WG + RX-E1+HDBX1000 MIP HP xw8600 2 x X5492 CPU 8 cores, 8G RAM, GTX1080TI. All sys Fibred to central media pool - 5TB RAID + QLogic Fibre Switch. Central SD Pro VCR rack. All sys YUV & audio to theatre with Sony STR DN1040 7.1 audio amp with 1000W sub 63" HD 3D Samsung TV
WS: Edius 6.55 / I5-2500K 3,3Ghz / ASUS P8Z68 deluxe gen3 / RAM: 8GB 1866Mhz / ASUS GTX550Ti 306.97 / Virtu green 1.2.114.21767 / 4x2TB WD / Win 7home 64bit / Neat Video / Adobe Premium Production CS6 / 3ds Max 2014
Cam: Sony EX1r / Nikon D750 / GoPro 3 black
GVST is free and work fine with 32bit edius.WS: Edius 6.55 / I5-2500K 3,3Ghz / ASUS P8Z68 deluxe gen3 / RAM: 8GB 1866Mhz / ASUS GTX550Ti 306.97 / Virtu green 1.2.114.21767 / 4x2TB WD / Win 7home 64bit / Neat Video / Adobe Premium Production CS6 / 3ds Max 2014
