Ive been using mercalli lately I like it for steading up some of my hand held work. Is there any way to multi-select a bunch of clips and drop it to a bunch at once? Some times I do bridal house coverage and its all hand held it gets a bit tedious setting every clip.
Adorage mercalli
Edius stabiliser
Edius 6.5 and 7 have a built in stabiliser which works just as well as mercalli, plus it works as a background task unlike prodad. Mercalli works per clip so each clip has to be analysed for stabilisation unlike the built in which is automatic.EDIUS 9.5 /Win 10 x64 Dell T5600 INTEL Xeon 16 core @2.66GHz 32GB RAM /NVIDIA GEFORCE GTX 1660TI, SSD SAMSUNG 500GB PRIMARY, WD 5.5TB STORAGE, 2x WD500GB ASSETS, heroglyph 4.0, Sony AVCHD cam, Canon DSLRs.
Sys 2: Asus ROG G75series -
There is a way to do it with Mercalli.
Set up Mercalli how you want it on a clip, then right click on Mercalli in the 'Information' tab and choose 'Save as current User Preset'. This should then save a copy of the Mercalli filter into the Prodad filters with the new settings. You can then just highlight all the clips you want to apply it to and drop on the new filter.
But as Alphabeta stated you still have to open up each clip to have it analyzed. This is probably because they expect you to check each clip individually to ensure the stabilizing is right for that clipDVC Built Clevo P775DM3-G Laptop with UHD screen, 7700K [email protected], Geforce GTX 1060 6GB GPU, 500GB M.2 Primary, 1x 480GB SSD, 1x1TB M.2, 1x 2TB 5400RPM Video drives, external Blu-ray OpticalComment
