safe and legal color plugin
  • safe and legal color plugin
    is there a quick function to make safe and legal colors in edius.
    in final cut there was broadcast safe plugin, it came quite handy when in a hurry. over the years i been just looking the scope but now hoping a faster solution. is there a third party plugin somewhere?
    working with edius 5.5
    Apply one of the color correction effects (except "3-way color correction"),
    there is a tick box to limit to broadcast safe color.
    Andreas
    Andreas Gumm
    post production / authoring
    Windows 7 Ultimate,
    GV hardware: 3G Storm
    PC 2
    GV hardware: HD SPARK
      In my experience that takes care of luminance only and by harsh clipping. For chroma it has no effect, I never found any automatic method of clamping chroma in Edius. It takes manual tweaking with vectorscope and waveform meter for each clip. For saturated colours I check legality by setting the waveform meter to "Comp" and keep the chroma between -20 and +120. For this I lower wb saturation in the 3-way color correction filter.
      Claire
        There's also NewBlueFX's Color Fixer Pro, part of their Video Essentials 5 Bundle but also available separately.
          Just remember that in EDIUS New Blue plugs don't support 10 bit yet . It just just something to think of if you are working with 10bit source material and you are producing for 10 bit delivery.
            Not sure about Chroma, but I never had issues on TV playouts!
            Andreas
            Andreas Gumm
            Windows 7 Ultimate,
            PC 2
              it is best to switch waveform to IRE mode and the vectorscope to line mode
              adjust Y levels with YUV curve
              adjust C levels with color balance filter, chroma level, reduce color until nothing shoots outside the circle in case of HD
              be sure preview mon overlay is off because it will show up in your levels as illegal, especially the VU meter
                i purchased the program and finally got it to work.
                my first reaction is quite careful, i put color fixer pro-effect on a self made illegal color clip and looked at the vectorscope and it didn't do move anything to safe color range area. maybe i'm doing something wrong but it seems that you just have to do everything more or less manually. the tagline of colorfixer pro says: Color Fixer Pro fixes color balance, while respecting broadcast-safe color values.
                anybody have comment or advice about this? like i said, maybe i'm doing something wrong. haven't had the time yet to dip in to the program deeply.
                thanx for the help.
                  thanx for the help.
                  yep, color fixer pro works just fine, had a little rookie problem. wonderful program/plugin, very usefull and quick.
                    As long as you are using 8 bit.
                      So you were eventually able to cut out the excessive chroma values in Edius with Color Fixer Pro? Besides reducing overall saturation I don't see any clamping down on illegal levels. Nothing I can instantly see that goes beyond what Edius color tools do, and likely easier. Is there some limiter function I'm missing? A hard ceiling for chroma? That would be the holy grail for me.
                      Desktop: Edius 8.50 WG/Win 7 Pro/HP Z620/Intel Xeon E5-1620 @ 3.60GHz/16GB RAM/NVIDIA Quadro 4000/Storm 3G
                      Laptop: 8.50 WG/Win 10 Home/ASUS ROG G751/Intel i7-4710HQ @ 2.50GHz/16GB RAM/NVIDIA GeForce GTX 970M
                        if you are shooting for broadcast, you should manually adjust levels for each clip until legal, instead of just clipping the access which reduces quality
                        I never tick safe color either, I manually use the YUV curve until correct Y level without clipping is achieved
                        if not for broadcast, you don't need to worry as much
