vistitle 2.5
  • vistitle 2.5
    i did full install from 2.5 from 2.35 it going ok can only plugin in edius 7 can not see it in edius 6 or 6.5
    1-ASUS TUF Z490 PLUS. I9 10850K CPU 3.6GHZ 3600. 10 CORES 20 LOGICAL PROCESSORS, GTX 1660 TI,64GB,STORM MOBILE,EDIUS X & EDIUS 9,DAVINCI.
    2.5 i think is for 64bit (E7)
      I have Vistitle 2.5.0.0 32bit and use it with Edius 6.55 with no problems.
        When you uninstalled 2.35 did you uninstall the Dongle drivers as well. That might be a separate uninstall. Look for an item called Sentinel System Driver Installer in the Programs and Features uninstall area.
        Then you will need to install the new drivers for 2.5.
          thanks for replay i try unstall the old vistitle and the key driver and install 2.5a plugin only edius 7 on the same computer i have edius 6 and 6.5 not plugin the old vistitle 2.3 works ok is there 2.5 32 bits
            Question how do you have EDIUS 7 6.5 and 6 on the same computer. Are you using separate disks?
              The main Vistitle installer includes both 32 & 64 bit versions and it works out what version you have on your system and installs the required version. If you've got more than 1 version of Edius on you system it may be confusing the installer as it probably expects to only find either the 32 or 64 bit software on there as you are not supposed to have more than 1 version of Edius on your system at any 1 time as they can conflict with each other
                I just have new computer put edius 7, 6.5 ,6.on same drive I did not start editing yet that must be creating a problem I have to unstall it.
                thanks
                  VisTitle installer only find the latest version of EDIUS in computer, if EDIUS7 was found, it only install 64bit, other if EDIUS 6 or 6.5 was found, it will only install 32bit, for 32bit, both 6 or 6.5 plugin will be installed.
