Audio Out of Sync with AW 4
    I have tested and confirm your findings
    59.94p elementary streams exported from EDIUS are totally out of sync in TAW5
    I will test Tmpeg5 Matering Works as an encoding tool, if that works, we know EDIUS is at fault, if it also fails, we know TAW5 can't handle 59.94P ES files
      I tested the encoding with Mastering Works5 and it keeps perfect sync in Authoring Works5
      so I will report this issue, it is an EDIUS fault
        after some testing, I found a temp workaround
        1. export to ES from EDIUS m2v+ac3 384
        2. when done, export the same section again as audio, dolby digital 384 and overwrite the one from the ES export (only takes a few seconds)
        3. author with perfect sync in TAW4 or 5
          Are only 59.94 projects affected?
            yes, 50p is fine and 50i is also fine
            I also make regular NTSC DVD from EDIUS ES export and they are also fine
            I have not tested 24p or 23.98p but I will do that as well just to be sure
            • #21
              23.98p, 24p and 59.94i are all fine, so only the 59.94p has an issue
              • #22
                Is your rounding on or off?
                • #23
                  in all my tests it was on, which is EDIUS default
                  should it be off?
                  • #24
                    Can you give it a try?
                    I will also check this .
                    • #25
                      tested with rounding off, still the same problem, but only with 59.94p
                      try 10min worth, by the time you get to 10min in the Blu-ray you will be out by almost a second
                      • #26
                        Thanks for confirming Anton. Since Edius is doing all of the encoding, there is really no need to use elementary streams. Program stream works fine and keeps sync. Also easier to keep track of one file.
                        • #27
                          but then TAW has to demux the file prior to remuxing
                          • #28
                            I did not notice anything in making the disc. When would this take place and would it have a negative impact? Any re-encoding?
                            • #29
                              no negative impact other than longer time needed to compile
                              • #30
                                That is good. It seemed to be a little quicker than ES actually.
