Prodad respeedr question 64bit into 32bit
  • Prodad respeedr question 64bit into 32bit
    Hi Guys, I have just been reviewing this super product on the prodad site and they recommend HD editing in the 64 bit version. The program is stand alone not a plug in. My system as you see is win 7/ edius 6.55 therefore 32 bit based. My question is, can I apply this process outside of Edius in the 64bit version of Respeedr, than pull that clip into My Edius 32 bit programme? (clearly out of my depth of understanding I'm afraid!)
    Cheers!
    Rod
    Rod Pike
    www.voxvideoproductions.co.nz
    A set of high quality paint brushes don't make you Rembrandt!
    Windows7-Edius 6.55-HDspark-VISTITLE v2.5.TMPGenc 5.vitascene v2-mercalli V2-Respeedr v1-Intel core i7 4770 8mb quad core processor-Asus Gryphon Z87 mobo- 16Gb ram-1 x samsung 256gb SSD 840 pro sata-2xWD 1tb sata caviar blue in raid 0-ASUS gtx 760 overclocked 2gb graphics card. Asus DRW 24 DVDRW DVD player-Cameras:Panasonic AC160A and AF102. and an 8kg cat who sleeps on my desk all day.
    Rod
    Yes, the mp4 or Mov files are independant
    If you are working in HD use the 64 bit version otherwise it will not work on some formats
    The files it will work with are only mpeg based, mp2 or mp4 / in and out, Edius has no problems with either or you can convert with AVCHD2HQ
    Works best if the footage is progressive
    Easy to export a Progressive 50p from a 50i project to mpeg2
    Can also be used to convert 25p to 50p using the "Optical flow" method
    I have put details for presets for export from Edius if you do a search for respeedr
    Regards Barry
      thanks so much Barry, greatly appreciated. Always nervous about asking really stupid questions, but I can take the pain as long as I am learning!
      Cheers!
      Rod
      Rod Pike
        Update: Respeedr now installed and works like a dream- I would also like to mention the superb email support from Bob at Prodad US who sorted out an installation problem on my Vitascene V2. Great product support-most impressed.
        Cheers!
        Rod
        Rod Pike
