MBL 2.5 coming soon
    i got looks 2.5 to work with edius 7.3 , i had to install it to CS6 instead of CS4 and show it in the 64bit(common folder) not the X86 one.
    Proud user of EDIUS!
      Lucky you. As soon as I open th Looks GUI everything becomes extremely unresponsive and Edius will lock up.
        The reason we currently advice to use the version on our compatibility list is that we are investigating issues with looks 2.5
        The Lock ups and unresponsiveness mentioned by Zorro are things we have also experienced.
        Remember that Looks 2.5 is just out and we Just released 7.3.
        The current list of supported plugs is valid for 7.3
          For a second i thought it was gonna work but....
          It seems i have the same problems as Zorro.
          I uninstalled MBL2.5 and now i am using 2.0 again (i really need MBL).
          I made a screencapture before uninstalling to show what is happening!
          https://www.youtube.com/watch?v=BiYF8gekV-A
          Sorry for my bad English ;)
            I finally had a chance to test it some. I can open the Looks GUI and play in it all day long. The trick is to click on the EDIUS icon in the Task Bar after the GUI is open which seems to activate the controls (Thanks for that lucky find).
            However, when I close that to go back into EDIUS, it crashes.
            As Steve suggested, I am not surprised to see a problem when it is first announced. I am sure it will be looked (sorry, I could not resist) into.
            • #21
              What do we hope to further fix it
              Windows 10 x64, Edius 6.55, Edius 8 Pro, Intel 4790K, ASUS Z87-PLUS , DDR 32 Gb, Nvidia GeForce 780 , Apple Cinema Display 27, Canopus NX with Expansion kit
              • #22
                We'll just have to wait and see when/if the engineers can address/solve it.
                • #23
                  To add to what Pat has posted we must not forget that both EDIUS 7.3 and Looks 2.5 are just out.
                  We have a finite amount of resources and our engineers will get to issues based on priority.
                  There is a working version of looks with EDIUS 7.3
                  Of course the issues with Looks 2.5 are noted and are being investigated.
                  For now please use the version which is on our compatibility list.
                  Thanks for understanding.
