What noise reducer do you use with Edius7?
  • What noise reducer do you use with Edius7?
    Thanks for some info.
    CPU: Intel i9 7940X
    SSD Drive:
    (C) 512GB Samsung 960 EVO PCIe M.2 NVMe (Windows 10)
    (D) 2TB Samsung SSD 850 EVO 2TB SATA III 6Gbit/s (for video exporting)
    (E) 1TB Samsung 960 EVO PCIe M.2 NVMe (for video editing)​​
    Please see Neat Video:http://www.neatvideo.com/
    It works great!!!!!
    MPPais
      NeatVideo for video noise.
      Usually Audition for sound work (v1.5, from before Adobe messed it up, wish I could find a v3.0 at a reasonable price).
        Adobe appear to be giving away audition 3 as 'end-of-life'.
        I think you need to have an adobe registration and log in, and have bought a previous version, though it's not clear. (I had CS4 which disappeared when a computer died, and the local network admins won't let me have it back. Will try audition 3 and see if it works.)
          Audio or video noise?
          You can reduce some types of video noise with Edius using the Median filter.
            Audio wise the Parametric Equalizer can do amazing things if you know how to use it. I've used it successfully for all kinds of noise removal. It won't remove a click or a pop but constant noise can be cleaned up nicely with it.
              Neat Video is great for cleaning up video noise
