Will this work with Edius 5.51 http://www.miraizon.com/products/codecsoverview.html
DNxHD and ProRes Codec Components
Mark Williams
[email protected]
http://vimeo.com/channels/3523
http://www.pond5.com/artist/mark29
Edius 8 WG, i7 6700K, Asus 170-A mobo, 16 GB Ram, System 960 Evo M.2, Video multiple 850 Evo SSDs, Shadow Rock Slim cpu cooler, On board graphics, Corsair 400c case, HD Spark, Windows 10, Panasonic GH6Tags: None -
What is the idea behind wanting it?
EDIUS supports Avid DNX an Prores natively. -
Yes I was just going trough it.
If Prores is needed it would make sense.
It should be accessible via quicktime.Comment
Not tested yet,
but it seems that this is the missed solution to create QuickTime ProRes files straight from the Edius timeline!
I assume that this has been developed with the help of ffmpeg, libav or ffmbc libraries.
Anyway, thanks for sharing this.
AndreasLast edited by Andreas_Gumm; 03-05-2014, 09:18 PM.Andreas Gumm
post production / authoring
Windows 7 Ultimate,
GV hardware: 3G Storm
PC 2
GV hardware: HD SPARK
software: Telestream Switch, DTS-HD MAS, Dolby Media MeterComment
Mark Williams
[email protected]
Edius 8 WG, i7 6700K, Asus 170-A mobo, 16 GB Ram, System 960 Evo M.2, Video multiple 850 Evo SSDs, Shadow Rock Slim cpu cooler, On board graphics, Corsair 400c case, HD Spark, Windows 10, Panasonic GH6Comment
Originally posted by More4KThis adds ProRes encoding on PC, but I am not sure if this is a licensed version.
If QT component is based on licensed Apple code than its nice add-on to QT on Windows.
I would first drop an email to them asking if it's Aple approved/licensed version.
Sadly I can't find a demo version.
AndreasAndreas Gumm
Windows 7 Ultimate,
PC 2
Originally posted by More4KIf this is based on ffmpeg than Apple won't be happy about it. And this company is selling it, so they will have Apple after them sooner or later.
So I will buy a license as soon as possible...
Apple could react to this with the next QT-"security" update to ignore the component.
AndreasAndreas Gumm
Windows 7 Ultimate,
PC 2
I just upated to QT 7.7.5 and Cinec 2.0 is still working.Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black Edius X.
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD.Comment
Yes,
because CINEC is not a QuickTime component!
The QuickTime API is not used with CINEC.
AndreasAndreas Gumm
Windows 7 Ultimate,
PC 2
so, has anyone tried this out? I see there is no trial available :-(
Paul :-)Edius Edits at: http://www.vimeo.com/user781619/videos
http://indiestereographer.blogspot.co.ukComment
I have exported now a full HD 1920x1080 25p clip with embedded 5.1 audio.
It simply works straight from the timeline, but it is really slow!
The 2 minutes clip took 6 minutes to export.
The codec of the exported clip will be identified as 'Miraizon ProRes 422 (HQ)' in clip properties.
So at the end I'm really really happy with it. Hopefully they will fasten up the encoding speed.
AndreasAndreas Gumm
Windows 7 Ultimate,
PC 2
Andreas Gumm
Windows 7 Ultimate,
PC 2
The codec can receive & encode at 10 bit.
AndreasAndreas Gumm
Windows 7 Ultimate,
PC 2
Originally posted by More4KLooks like quite solid implementation, but you still have no guarantee that you can get 10bit out of Edius. GV passes (I think) r4fl format (Y'CbCr 32-bit floating point 4:4:4:4, superblack support) to QT component for 10bit support. Plugin supports only v210 or v216 on input for 10bit encoding. It may work or may not- needs testing.
The plugin also supports QuickTime ‘v410’ for 10 bit 4:4:4 video.Comment
