Originally posted by Andreas_Gumm
View Post
TMPGEnc Movie Plug-in AVC for EDIUS Pro 7
Originally posted by Hawke View PostClaire, Yes; I tried your workaround and it worked but one shouldn't have to do that.
I am having trouble producing a Blu-ray disc from the m2ts file produced, it has been stated here that Edius disc burner will do that but it does not, requesting an image file. I am doing something wrong obviously or need an extra stage in the process, any help would be appreciated.
Have NOT yet been able to make a workable disc with a file from the plugin, still trying.Claire
Originally posted by GrassValley_SL View PostSince EDIUS has Lanzcos downscale you could feed the encoder a scaled stream. :)
it does not happen when switching EDIUS from 1920x1080 to SD such as 720x576Attached FilesAnton Strauss
Originally posted by Claire View PostDon't use the one in the tools menu, see page 439 of the manual for "Burn to Disc". To add the file from the plug-in click the movie tab and press the 'Add File' button to browse to it. Use the delete button to remove any already existing timeline or sequence. Edius doesn't like my early Pioneer drive so have to burn folders and use ImgBurn to write a BD.
Blu-ray burnt, even with menu and plays perfectly. Time to create .m2ts file 35 minutes without Spurs engine, 10 minutes using Firecoder Blu. 2 minutes to write disc. Test sequence length 15 minutes. Long live FCB!Hawke,
Edius 8.31WG - Asus Sabertooth X58 - 3.2GHz I7 960 - 12GB RAM - SSD C drive - Win7 Pro. 64bit - BM Intensity pro 4K. TMPGEnc Movie plug-in. FCB. Sony PMW-EX1 & Panasonic HDC-SD900. Atomos Samurai Blade
Originally posted by More4KThis grid is on your source also- you can see it. Its just 'smaller' because resolution is high.
You loose it in PAL because you downscale by large amount.
Do you see anything in the actual picture?
Is it the same for every source?
It has been reported many moons agoAnton Strauss
I think that More4k means it is already in the source!
The waveform has tendencies to show a grid already in the source resolution.
Even in your source.
AndreasAndreas Gumm
post production / authoring
Windows 7 Ultimate,
GV hardware: 3G Storm
PC 2
GV hardware: HD SPARK
Cannot get files made with the plug-in to pass through Disc Burner without it halting.
"An error occurred while creating the disc image file".
Heck, I'm not even trying to write to disc yet, just want to make the image file in the folders.
I am getting fed up with this plug-in, about to give up on it.Claire
Yes, I used a BD template and others as well.
I am wondering if the problem is a mix of two problems, not too confident Disc Burner is working properly and/or the files from the plug-in are not quite correct.
By accident I found that if I make a 24p file with the preset and if I also change the menu frame rate in Disc Burner from auto to 24p 1920x1080 I can successfully write a 24p disc but not if I leave it on auto (this is on Disc Burner's "Style" tab).
The odd thing here is that I can't see any other frame rate for the menu in this drop down box than 24p... even when I'm using Disc burner in a 50i project. Am I alone in this, should there not be 25fps and 29.97 showing as well as 24P?
It gets more weird, I can build a working folder of a 50i disc image with Disc Burner IF and only IF I change the menu frame rate from auto to 24p... crazy.Last edited by Claire; 03-11-2014, 12:44 AM.Claire
why would you use the Tmpg encoded footage as a source for disk burner? the disk burner will re-encode it again, in other words you waste time
or are you making a complete BDMV folder structure and only using the disk burner to burn?Anton Strauss
Hello Anton,
Well, the plug-in makes the avc files which if it worked Disc Burner could author them into a simple menu Blu-ray disc. It does not attempt to recode them.Claire
I am unaware of the fact that disk burner can compile without re-encoding
possibly due to the fact that I avoid disk burnerAnton Strauss
I believe it only encodes timelines and sequences and seemingly not when you use the Add File button (movie tab), which makes sense since it looks for files such as mpeg and vob.Claire
hmmm, I have to try that in order to believe itAnton Strauss
I exported a Blu-ray compliant m2ts using the built in EDIUS exporter and loaded it as a file in Disk Burner
there was no option to tell the Disk burner not to re-encode, but it did not re-encode
so your assumption was correctAnton Strauss
Originally posted by More4KI did not use menus, so maybe that's why it worked for me.
The plug-in's std template "Blue-ray (BDMV, PAL) - H.264/avc" when used to export an Edius 50i timeline is flawed. In addition to producing incorrect colours it also has motion stutter problems unless written to disc from Disc Burner without a menu.
Exception is with a 24p project where if I manually change the menu frame rate in Disc Burner from auto to 24p motion is then fine but of course still has incorrect colors.
In my many attempts with 25fps I have continuously inspected the m2ts files in Disc Burners output folders and sometimes found that while the movie file is correct at 25fps, the menu file is only 24 despite being on auto! I feel sure this is to do with the menu frame rate selector in Disc Burner only having two options, either auto or 24.
What I would like to know, since I cannot select 25, is the auto working when files are added rather than just letting Edius export mpeg from the timeline?Claire
