iZotope Audio VST Plugins for Edius 7?
  • iZotope Audio VST Plugins for Edius 7?
    Hi,
    I just upgraded to Edius 7 from Edius 5.51 and used to use iZotope Audio VST Plugins to get my audio levels even.
    Is there something comparable for Edius 7?
    Or a way to do with Edius 7 Audio filters?
    Thank You,
    -Dwayne Gitter
    Edius 7 is 64bit. You must have the 64bit version This will apply to E7 plugins
    Previous to Edius 7 they were 32bit
      Ozone 5, Nectar 2, Alloy 2, and RX3(RX2) all work with Edius 7.
        Wave Arts work as well.
          Wave Arts
          Hi Bassman,
          Where can I get Wave Arts and what is the price?
          Thank you for responding,
          Dwayne Gitter
            Wavearts:
            We make audio plug-ins for mixing, mastering, restoration, and sound design, combining innovation with thoughtful user-interface.
            I would suggest to have a look at Voxengo:
            Discover and download paid and free VST plugins, AU plugins, AAX audio plugins, mastering plugins, equalizer plugins, compressor plugins.
            Comprehensive vocal effect plugin with brilliant sound, multitude of features, and easiness of tuning. Works best for vocals, and can be used for a wide range of instruments.
            Transparent mastering limiter (loudness maximizer) plugin. Features dithering, statistics, multiple modes, oversampling, graphs, and a very clean sound.
            Good deal for noise reduction:
            The use of this site provided by us (Acon AS of Norway) subject to the following Terms & Conditions. Read them to make sure you agree.
              Originally posted by dvideo321 View Post
              Hi Bassman,
              Dwayne Gitter
              B&H has a good price. I only have the Track Plug but it does a lot.
