EDIUS 7.21.822: stuttering timeline with prodad VITASCENE 2.0 filter
  • EDIUS 7.21.822: stuttering timeline with prodad VITASCENE 2.0 filter
    Hi,
    Since using the new Edius 7.21.822 version in combination with the Prodad Vitascene 2.0 plugin, I need to render all my timelines after applying a Prodad Filter. Nice and smooth play-back of the filter at the time line is not possible "real time" (only with stuttering).
    A verry annoying way of working after I worked with Edius 6.5 with Prodad Vitascene plugin without any issue and really "real time".
    Also the preview of the filter in the Prodad filter preview screen freezes and preview playback.
    I've contacted the Prodad-team, but I've got (more or less) the advice to go back to my Edius 6.5 version or purchase a new computer.... not exactly the support answer I was hoping for.
    Could you help me out with this issue Guys?
    Will
    If Prodad gave you the advise based on system spec you provided there is really nothing we can do.
    Remember that EDIUS 7 is 64 bit and it has different requirements compared to the 32 bit version.
    Also it would be helpfull if you post your system specs.
      You have a Prodad Vitascene 2.0 plugin (32bit) and you can do a free update.It works great with Edius Pro 7. In your account you have Service-Update and you can download: Download Installer 64-Bit (Windows) with the last version.
      MPPais
        I've read the manual, and I'm aware it is a 64-bit based program.
        This is my system configuration:
        Microsoft Windows 7 Home Premium 6.1.7601 Service Pack 1 Build 7601, NVIDIA GeForce GTX 550 Ti / RAM-memory 1,00 GB / Systeemtype x64-bit /Processor Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz, 3401 MHz, 4 core('s), 8 logical processor(s), Memory (RAM) 8,00 GB
        According to the specified system requirements at the manual, It should be OK.
        I see that the buffer at playback is influencing the realtime preformance. With the shift-spacebar keyboard combination it runs OK till the buffer is back to "1" again. Resizing the systembuffer to 2Gb didn't result into a positive effect.
        I downloaded today the latest Vitascene 2.0 update for the 64-bit system. No positive effect to the "realtime" playback.
        Appreciate your feedback.
        Will
          My systemconfiguration =
          To solve the issue A connection to the resize buffersize looks to be an option.
          Any idea how to manage this?
          Regards,
          Wiel
            Which EXACT Prodad filter or transition are you using?
            Are you using the default settings or have you nodified them? If you have modified them, make a screen shot of the Prodad panel.
            Also post a screen shot of your project settings.
            What type of file or files are you applying either the filter or transition to?
              I just did this on my system onec I installed Edius 7. I had Vitascene 2.0.189 which was the 32 bit version, the newest is like 2.0.228 or something like that which is the 64 bit one. Updated and works ok on mine.
              Just check your ProDAD version.
              Jeff
              Created Design Video
              "Video production for the common man"
              Sager NP9170 i7-3160qm, 8GB ram, 480GB SSD, 240GB HD, GTX675m, 17" HD, Win 10 home 64bit
              Panasonic AG-HMC40, AC-160a,
              Edius Pro 8.53
                Issue related to Graphics card + Frame size
                It turned out that the problem is linked to the Graphics card and the combination with the setting Frame size at the project settings.
                Although my graphics card has a 2Gb memory the GPX only works fine when at the project the frame size is set to 640 x 680. Al (higher) sizes result in stuttering movies.
                I need to consider a new graphics card to get the problem solved. The defined system requirements are the bare minimum but is not OK for smooth working with Edius.
                Thanks all for your support, ideas and help
                Will
