Is Vistitle 2.50 tested with Edius 6.55 ?? ....
history:
works well in Edius 6.54 for me
update to Edius 6.55
behind the update I test (for pictures and own experience) the workaround
for to run Edius 6.5x without Vistitle-dongle
the workaround does the job,and Edius 6.55 runs without Vistitle-dongle
now some weeks later, I rename the file from VtEDIUSImporter7
back to his original extension VtEDIUSImporter7.tpi
and now Vistitle 2.50 crash Edius 6.55
restart the PC behind renam ... solve not the Problem
deinstall and new install Vistitle 2.50 (with full installer) .... solve not the problem
so I have the sneaking suspicion, especially behind new install Vistitle 2.50
it is eventually more in cause to 6.55 as to my rename and rename back test
As "standalone" ... no problem, only in cause to Edius 6.55
is there a know, about updated Edius 6.55 + Vistitle 2.50 problem??
runs some user well with updated Edius 6.55 + Vistitle 2.50 ??
friendly asked greetings from ....Central€urope
history:
Originally Posted by VX Chen
Do you rename VtEDIUSImporter.tpi in EDIUS\PlugIn folder ?
http://forum.grassvalley.com/forum/s...ad.php?t=31615
