Steve, could you try the file and see if it works?
Random text blur in FX
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black.
John had an issue with the file last night. That's why I asked.Jerry
I don't get it. I have tried the steps and did the rename, bur the file still shows up as a PHP file, I have no idea what that is.tdtinker
New system: Asus X99 i7 6900K 3.2GHz, 32GB DDR 4 Ram, GTX 1070 Edius 8.5
www.actvp.com
PM me your email address and I will send the layout that way.Jerry
I just sent it by way of your dropbox.Jerry
I opened both of them and it opened the layout, but there was nothing in it either one.1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
Thanks Jerry got it in drop box.tdtinker
www.actvp.com
Originally posted by GrassValley_PS View PostI opened both of them and it opened the layout, but there was nothing in it either one.Attached Files
Originally posted by Jerry View PostJust sent you the updated version. Play with the text and length of the clip. Also, you can change the blur type that I used.tdtinker
www.actvp.com
If you look at the layout you should be able to figure it out.Jerry
Originally posted by Jerry View PostIf you look at the layout you should be able to figure it out.
You don't know who you are dealing with. But I'm on it.
Thank you.tdtinker
www.actvp.com
Originally posted by Jerry View PostIf you look at the layout you should be able to figure it out.tdtinker
www.actvp.com
