Did you have problems with the file I sent you or is this something else? The PHP file is in a code language that relates to the web egine. Will it open in notepad?
OK. try this one: blur title.vtlayout.zip
Do the same. Right click on the zip file and choose rename. Remove the .zip extension and save. then you will just have the layout.
Think maybe the steps will help:
1click on the attached file
2 choose save
3 Let it download.
4 Go to the file on your disk
5 right click choose rename and remove the .zip
6 You will get a warning that the file may get unusable click yes.
7 now you will have blur title.vtlayout
8 import that in EDIUS put it on the timeline
