Vistitler vs After FX
  • Vistitler vs After FX
    What are the advantages of using vistitle over AFX for motion titles?
    tdtinker
    tdtinker
    Edius 8.5
    www.actvp.com
    I used to use AE for titles. But being able to make titles as well as doing true 3D graphics, Vistitle has a definite advantage.
    This will mean 3d titles that adjust to perdpective in real time.
    Vistitle has a 3d modeler built in as well. It is not the equivalent of a true 3d modeler, but it is there.
    If you have used AE for a while, the interface will feel familiar.
    Lastly, the fact that Vistitle is a plugin allows you the ability to modify those titles on the fly as opposed to having to fix and export the title again.
      It may be a psychological thing but what I love the most about VisTitle ist picture quality. Titles never looked so good.
        Vistitle works inside EDIUS as a plug-in with lots of quick templates you can drag on to the timeline. It has particle effects which After Effects does not have and I like using. It is easy to use and you can make some fairly good titles just by adjusting the templates.
        After Effects does a lot of other stuff but I struggle to make it do some of the things I can do quickly in Vistitle. Also going to another program (After Effects) and then exporting videos is a pain, making multiple titles all based on the same one is a lot easier in Vistitle. One thing I do is make a sales presentation for video shows I do which consists of lots of titles showing prices and information. For one show I did the lot in After Effects and it worked, and looked good and took about an hour and half to render the entire thing. I did the same in Vistitle this year and it was far quicker and mostly realtime.
        Vistitle is £200 to £240 (if you want it with the extra plug-ins). After Effects is either £700 or £20 per month using the Cloud.
        I am a reseller and sell both and also use both programs. I use Vistitle for titles and After Effects for effects.
          David,
          thanks for you input.
          tdtinker
          Edius 8.5
          www.actvp.com
            Don't forget the subtitle editor in Vistitle.
            It can load & export subtitle scripts easily, the render quality is great.
            Andreas
            Andreas Gumm
            post production / authoring
            Windows 7 Ultimate,
            GV hardware: 3G Storm
            PC 2
            GV hardware: HD SPARK
