Edius 6.53 crashes without Vistitle Usb Dongle
  • Edius 6.53 crashes without Vistitle Usb Dongle
    Hello everybody
    I am working on a project in Edius 6.53 on both my Pc and Laptop.
    The problem is that i have to also work in Vistitle 2.5.0, so that means every time i need to work with Vistitle in my laptop i have first to disconnect the Vistitle's dongle from the Pc and then connect it to the Laptop and works fine.
    But for some reason i needed to open the Edius in my Pc with teamviewer in order to export some photos and upload them to my Laptop.
    Impossible. The Edius crashes without the Usb dongle inserted.
    The same happens to The Laptop if the Dongle is not conneted.
    with the previous version of Vistitle 1.87 there was a message that the dongle is not detected (if it was not connected) but i could open my projects without issues.
    Ok it is not THE big problem, but it is something that i need to solve because from time to time i have to switch from pc to laptop in order to work with Edius.
    Any Ideas???
    Computer Details
    Gigabyte Z490 Gaming X
    Core i7 10700K @3.8GHz (8 Cores 16 Threads)
    32GB DDR4 (2*[email protected] Mhz Corsair)
    1*500 GB NVME EVO 970 plus(O.S and programs)
    2*1TB SSD Samsung EVO 870 Raid 0 for Editing
    1 Sata Dvd-R
    Nvidia GTX 1060 OC 6GB Ram 192Bit
    2 LG IPS235v-BN Led 23"
    Windows 10 Professional x64
    Intensity Pro
    Edius Workgroup 9.55.7761
    Vistititle 2.9.0.1
    Once you go Mac you may come back!!
    Once you use FCP, you always need to render
    Thats why i switch to Edius !!!
    it is a know problem, her is the thread, including a workaround from VX Chen
    to rename the VtEDIUSImporter7.tpi files in your EDIUS\Plugin folder.
    http://forum.grassvalley.com/forum/s...ad.php?t=31360
    hope it helps ... ;-)
      Thanks for your answer.
      i renamed the file, then renamed the extension, renamed everything, but the problem is still there....
      Computer Details
      1 Sata Dvd-R
      Intensity Pro
      Vistititle 2.9.0.1
        Do you rename VtEDIUSImporter.tpi in EDIUS\PlugIn folder ?
        Or you can move the file to your desktop, when you need it, you recover it to EDIUS\plugin folder again.
        Sorry for this trouble, it is the bug of 2.5, it can be fixed in next update.
          Thank you very much VX Chen
          Removing the file solved the problem.
          Everything is OK now, and Edius loads as it should !!!
          Thanks again
          Computer Details
          1 Sata Dvd-R
          Intensity Pro
          Vistititle 2.9.0.1
            test on
            german win_7 prof 64 bit
            german localized Edius 6.55
            VisTitle installed, but dongle not insert
            rename the filename (like picture_1) => did not work,
            it crash Edius ditto with the "error module" mfc100u.dll (picture_2)
            rename the file-extension => solve the problem (picture_3)
            remove the file-extension => solve the problem
            so you need not absolute to move the file to your desktop,
            but you can do it => it solve ditto the problem
