Vistitler Feather ends of bar
  • Vistitler Feather ends of bar
    I want to Feather both ends of bar or line in vistitler, any suggestion as to how to do this?
    tdtinker
    tdtinker
    Edius 8.5
    www.actvp.com
    Is this what you are looking to do?
      yes it is Jerry, Did you do it in Vistitler?
      tdtinker
      tdtinker
      Edius 8.5
      www.actvp.com
        That is done with a mask. I imported the ellipse_2.bmp from the Edius Alpha folder into the Vistitle System library under the channel header. Then you check mask and invert and adjust your blur to your tast.
        Make sure that you have face selected.
        This is one way. The other is to use the gradient tool under the Colour expansion arrow through the Face panel.
        Here is a layout:
        Feather layout.zip
          Thanks, When I get back to office tomorrow, I'll give it a try.
          tdtinker
          tdtinker
          Edius 8.5
          www.actvp.com
            once the light goes on with the vistitle gradient settings, you will find it fast and easy
              That's the way I do it fast and easy. :)]You can also chose transparency instead of a color which gives you more options to do crazy stuff.
                Thank you everyone it works great, now how about feather top and bottom and both ends?
                tdtinker
                tdtinker
                Edius 8.5
                www.actvp.com
                  tdtinker
                  enable the alpha mask and choose a suitable alpha mask, or load your own custom mask image
