Transfering footage
  • Transfering footage
    My options are a bit limited on how I can transfer the Mini-DV Tapes to my Laptop for editing with Edius. I have to go through a PC that I had Avid Liquid Pro built for a couple years ago via firewire. Than I transfer to portable drive and download to laptop. Is there a better way? I plan to invest in a camera that shoots on the SD cards ASAP but am disappointed in footage quality upon transfer. Any thoughts?
    Does your laptop have an expansion port?
    If it does you could use something like this to transfer the DV tapes directly into Edius:
    http://www.amazon.co.uk/Belkin-Firew.../dp/B000225I4E
      that means your laptop has no firewire port, correct?
        No firewire port, HDMI / USB / SD Card slot
          You might want to see if you can get a Firestore device. IIRC, you could disconnect it from the camera and connect it to a computer as an external drive.
          You would still have to transfer/capture the footage from the camera/deck to the Firestore, but at least you could skip the export/transfer to the external drive, as it's already on the external drive.
            Longest time is the capture from tape. You could capture straight to a portable drive attached to the PC with IEEE1394 and then just edit from that drive on the laptop. USB2 is fast enough for a single stream of DV or HDV. After you have the files on that disc for backup storage. USB only has a problem with isochronous stream from a tape it is fine for file transfer. Camera to PC is isochronous but PC to the USB drive is a file transfer with all the RAM in the PC to use as a buffer. DV/HDV tape is about 3.5 MBps and most USB 2 hard drives will sustain close to 20MBps.
            Ron Evans
            Ron Evans
