Since 6.5 we don't bundle thirdparty plug-ins. If you own the plug-in for 6.5 the update to the version for EDIUS 7 is free.
So case in point your serial number for the purchased version for 6.5 would be valid for the update to the version for EDIUS 7.
Just so I understand, I would have had to purchased Vitascene from Prodad for Edius 6.5 in order to update the version for Edius 7.
All I have now is Vitascene LE 1 so I would need to go to their site and upgrade to the latest version?
Jim
That is correct you would need to check which update path Prodad offers.
Good luck with that one! Earlier this year I wanted to upgrade my Heroglyph title programe, I checked on their website & found it was compatable with 6.o5, so I bought it only to find that it wasn`t directly compatable. I contacted prodad who told me I`d need to got to Edius 6.5, which would have meant not only the cost of that plus I would need to purchase vistitle & Mercali. Rang them in Germany, ended it up by being sworn at (I speak a little German). I contacted my credit company who agreed that the website had misrepresented the compatability issue & refunded my ÂŁ133! So as I said at the start, "Good luck"
You will be very happy with the performance of Vitascene within Edius 7.
Hi there,
I have Edius 7.21 and got Vitascene 2. In my case the performance is very poor, I can not add filters in realtime, rendering is very slow (15xrealtime)
I have a Corei7-4770K on an Intel DZ87KLT-75K Mainboard, 32 GB RAM, 2x 240 GB SSD RAID, Intel HD4600 onboard for quicksync and an NVidia Quadro K2000 2 GB for the rendering of the effects.
It seems that Vitascene does not use the Quadro at all, even if I did set it on Edius (GPU-Effects). ProDad told me that the Quadro is too poor (!) to perform real-time effect rendering on 1080i50.
I understand but I was just pointing out that if the manufacturer says that a certain GPU will not give optimal performance it is hard to argue against it. :)
