Vistitle 2.5 / Edius 7.01 / win_7+SP1 german / 1080i 25 (old name 1080 50i) project / overscan 0%
create a colormatte 235/235/235 in Edius on VA_1
create a object with 255/255/255 in vistitle set it to VA_2
on bootom and top from the objects are coming out strange lines
these lines are ditto in exported files available
the 255/255/255 are correct converted (not clipped) to 235/235/235 on the timeline
you can not find one point 255 with the vectorscope....
look at the attachement_1
for better to see the the original- form from the objects
look at attachement_2 ... here it is the color from objects in Vistitle set to 237/237/237
Is this my user error, have I forgotten some basic setting to make ??
or can this anyone confirm??
If i try the same in the poor GV Quicktitler .... no strange lines on any part from the object
a other difference is .. in Quicktitler I have the color set to 235/235/235 instead of 255/255/255 in Vistitle
for identity color with the Edius 235/235/235 colormatte.
If I set in quicktitler a object to 255/255/255 ... it is clipped for the timeline view to 235
but 255 is visible with the vectorscope
thanking you in anticipation for some clear up words / or some confirmation
