trouble finding Vistitle 2.5 in Edius 6.55
  • trouble finding Vistitle 2.5 in Edius 6.55
    I am running Edius 6.55 and just upgraded to Vistitle 2.5. Downloaded it and put in the serial number and installed it. I see the stand alone 2.5 but do not see it in Edius 6.55.
    I read the Vistitle PDF and don't see any special instructions. Its says----
    Launch EDIUS 6.0X, EDIUS6.5X, or EDIUS 7, click “Tools” in the menu bar, then click “EDIUS Title Templates Library” or just press the shortcut keys: Ctrl + F12
    However when I look there I see no Vistitle or Edius Title Templates.
    Is there a step I am missing?
    Jim
    Are you running Windows 8?
      No Windows 7 64bit.
        Do you have an anti virus installed? If so, turn off the anti virus and try installing as administrator.
          Which Vistitle version did you upgrade from?
            Jim
            Do you have use the latest VisTitle 2.5 installer in www.vistitle.com ?
            Can you make sure there is a VtEDIUSImporter7.tpi files in Edius plugin folder?
            If that tpi is not there, then maybe when installing, some anti-virus program had killed that file. Try to close it, and reinstall.
              Vistitle 1.5
                Yes I have the latest Vistitle 2.5 for the Vistitle site. I have disabled my anti-virus program and reinstalled Vistitle 2.5 rebooted and checked in Edius 6.55 and still it's not there. I do have VtEDIUSImporter7.tpi in the plug in folder.
                Not sure what is going on.
                  http://c3.safenet-inc.com/downloads/...er%207.5.8.zip
                  This is the latest dongle driver. It is worth trying.
                    Just one thing tho if the OP is using 6.55 shouldn't the tpi be for 6.5?
                    I don't a have 6.55 installation but I think that since 6.5 is 32 bit a 6.5x tpi should be in the plug-in folder not a 7 tpi which is for 64 bit.
                    It could be that the wrong version was chosen at installation.
                      That is a good point I missed that. I downloaded the latest Vistitle 2.5 but in the Vistitle PDF is says 2.5 is for 6.x 6.5x and 7.
                      It did not give me a choice while installing Vistitle 2.5, it just installed.
                      Jerry I did update the driver you gave me and still no Vistitle.
                      Vistitle did give me 2 serials numbers, one for full install and one for upgrade.
                      I used the upgrade since I have 1.5 on my machine. Do you think that could have had any effect?
                        I think it is the tpi.
                        What I would recommend is download the full installation of 2.5.
                        Open your current installation go to about and copy the serial number and paste it in notepad.
                        Then uninstall vistitle. Go to the plug-in folder and make sure the EDIUS 7 tpi is removed.
                        Use the full installer which I know for 100% will give you a selection.
                        Select EDIUS 6.5
                          Select EDIUS 6.5
                          Ok, I will try that. If I am not mistaken I did download the full version of Vistitle 2.5 and installed that and now I no longer have 1.5 on my machine. Vistitle 2.5 uninstalled 1.5. I only needed the 1.5 serial to buy 2.5.
                          I will uninstall 2.5 and re install that. Vistitle sent me 2 serials, one for upgrade and one for full install at least thats what it said.
                          It did not give me any choice for what Edius I have so not sure I can select Edius 6.5.
                          If this does not work I might have to wait until I get Edius 7 which I am getting as soon as they send me a link to download 7. I bought 6.5 in the time window that allows me to upgrade to 7 for free.
                            Did all you suggested and Edius 6.55 still does not see Vistitle.
                            Not sure what to do next. Wish Vistitle had a support number.
                              I have just installed Vistitle 2.5 on a system with EDIUS 6.55 and it turned up immediately. The plug in is called VtEDIUSImporter7.tpi, even though it is in EDIUS 6.55.
                              You say there is nothing under tools (the template library etc) what about when you click the T button on the timeline, is Vistitle listed?
                              I had a problem with the title template library in EDIUS 7/Windows 8, that seemed to be caused by premissions and Vistitle needing to be run "as administrator" so something similar could possibly stop the template library appearing in Windows 7 (maybe). However I still had Vistitle listed on the "T" button on the timeline and could use it.
                              Other questions (the answer to which may or may not help):
                              • Are you logged on as administrator?
                              • What graphic card are you using and with which drivers?
                              • Have you tried deleting your user profile and setting up a new one (sometimes fixes odd things)
