Help with Wavearts VST Plugin, Edius 7
  • Help with Wavearts VST Plugin, Edius 7
    I downloaded the Wavearts Trackplug VST filter, installed it and pointed the installer to place the files in the VST folder of Edius.
    When I go into Edius that VST folder is listed under VST effects but the effect does not show in the effect window.
    Have I missed a step? Anton said the Wavearts restoration worked with Edius 7, so I am trying out the EQ etc...
    Thanks for your help
    Are you sure you installed the 64 bit version of the VST package?
      Thanks! I went back to the site and found the 64bit version.
        Great! Have fun. :) Good plugs.
          Seems to me Edius 7 have real problem with x64 vst plugins
          Today update edius still crashes when loading at splashscreen, when powersuite from wavearts installed ( x64 version at their own folder and pointed in system/effects/vst section in edius 7)
          Steinberg invisible limitter x64 crushes Edius 7 when I open "properties" button on effect pallette
          Does anybody knows, is there a method to use any kind of vst plugins in Edius 7?
            Izotope Ozone 5 works fine
              The Master Restoration plugs will work but the Power Suite has issues.
                Power Suite has no issues - Edius does.
                So strange that Edius has had VST problems its entire life - first none at all, then half ****.
                The was never resolved properly it seems, all other software says VST on the package and it works, with anything - why is Edius is so lame in this respect I wonder?
                Surely it is VST compatible or not - and it isn't - misleading I'd say, a bit like the AE Bridge - essentially it doesn't work, as it only operates with err, is it two plugins or three? - so, about 0.1% of available AE plugs - again quite misleading for a would- be purchaser.
                c'mon GV get crackin'
                Paul :-)
                  You misinterpreted what I said. I said that the Master Restoration plugins will work (with Edius) but Power Suite had isssues (with Edius).
