Vistitle 2.5 and E7
  • Vistitle 2.5 and E7
    Just loaded E7 then Vistitle 2.5 . I can see it on the desktop and can open it individually but it does not show in E7.
    E9 PRO ,Intensity Shuttle capture Nvidia 650 TI LG 3D Monitor HDMI Win 10 PRO 64 Bit.Vistitle 2.6, Robuskey. ASUS Z370 I7 8700 16 GB Hyper X black RAM 250GB 960 EVO. 2 ITB Disks
    Did you have an earlier version of Edius on your machine before? If so uninstall Vistitle then makes sure you no longer have any of the folders for the early version then reinstall Vistitle
      If this is on Win 8, and you did not install each program as administrator, this might be the problem. Your signature says Win 8.
        http://forum.grassvalley.com/forum/s...ad.php?t=30760
        look at the piture in pos #1
        additional to Jerry ... we have here some test with Vistitle run
        in win_8 it looks... you need Edius to run with EDIUS.exe per => Properties / Compatibility
        the "Privilege Level" to >run this programm as administrator<
        additionl to Adbear... we have here some test with Vistitle run
        your words are very true .... I have a test PC for to see user problems
        with a setup, aside from "Antons" rules
        simple ...only install, what Grass Valley document tells (without delete the folders)
        so I have become on this PC a profile in E_7 ..with some from 6.5 inherit things
        what crash Edius in cause to open Vistitle
        with a "new in E_7" created profile .... no crash
        the same profile in E_7 ..with some from 6.5 inherit things
        have some reprocable crashes in Layouter in cause to the Graph-editor
        some users tell the same ... with a similar Installation
          Following a combination of your advice posts Vistitle is working now. Thankyou
            Please elaborate on what you did. It might help others in the process.
