How to Get Vistitle support
  • How to Get Vistitle support
    The contact page just shows retail dealers. There's no way to ask a question ! My issue, and I hope they're reading this, is why aren't I seeing the file selection property when I try to add an image to VT? See Attached.
    How do I import an image if there's no way to select it???
    Thank you.
    Gigabyte mobo with i7 K2600, 16G Ram, Storm Mobile, nVidia 570 but I'm just a hobbyist.
    Have you tried using the browse option atout 75% down on the the properties panel. Its not just for 3D
    VX Chen the author frequently appears here so if nobody else has helped he will chime in personally. They have excellent support and very personal here on the forum
      Thank you.
      Please click the "Browse" button in right property panel of image object to select your image.
      Or, you can try drag-drop your image file from windows explorer to VisTitle edit view.
      BTW, you can contact with us with [email protected].
        Must need new glasses!
        Didn't look under the 3D section as I'm working in 2D and didn't expect to look there. My error. Thank you for all your help.
          While you can go through the 3D panel, this might be easier for you to do:
          Import Image.wmv
          Both import methods work in the video. Since I already had the same file in the bin it just reminded me of that.
