vistitle stencil effect on strapline
    Jerry that is exactly what I wanted. I didn't know about the Boolean action- however, I still can't duplicate your example as the Boolean sub menu (Xor etc) are all greyed out. I have duplicated everything on your video exactly but I must have a setting wrong somewhere, or have missed an action.
    What I am doing is:
    draw rectangle
    enter text- choose white and align on rectangle
    group using elastic band
    open up drop down menu by right click on text
    scroll down to Boolean- open up sub menu----all greyed out and I can go no further. Have I missed a step somewhere? I have gone through your example frame by frame and I think I have it all.
    Rod
    Rod Pike
    www.voxvideoproductions.co.nz
    A set of high quality paint brushes don't make you Rembrandt!
    Windows7-Edius 6.55-HDspark-VISTITLE v2.5.TMPGenc 5.vitascene v2-mercalli V2-Respeedr v1-Intel core i7 4770 8mb quad core processor-Asus Gryphon Z87 mobo- 16Gb ram-1 x samsung 256gb SSD 840 pro sata-2xWD 1tb sata caviar blue in raid 0-ASUS gtx 760 overclocked 2gb graphics card. Asus DRW 24 DVDRW DVD player-Cameras:Panasonic AC160A and AF102. and an 8kg cat who sleeps on my desk all day.
      click the title, then ctrl+click the bg banner, then right click and the options will work
        Hi Anton, the Boolean submenu is still greyed out. I have tried my vistitle freestanding as well , just in case it was something in Edius that I have wrong, but still no-go.
        I have also changed the test project setting in 1920 1080p and I. just in case it was a format thing, but no luck. anything else I can try? thanks to all for your support on this.
        Rod
        Rod Pike
          Ok watch this:
          Vistitle Cutout 2.wmv
            be sure the title layer is below the rectangle
            click mouse below title layer and drag rubberband upwards until both items are selected, see here
            then right click anywhere in the rectangle
            • #21
              Hi Jerry, Anton,
              Followed your instructions to the letter- the Boolean sub menu is still greyed out. This is going to be something really silly but OK I'm prepared to look daft (had a lot of practice over the years!)!!
              So could you give me the best way to upload a video to show you exactly what I am doing? although I believe it is identical to what you have shown me.
              Rod
              Rod Pike
              • #22
                Originally posted by rodpike View Post
                Hi Jerry, Anton,
                Rod
                Please make sure to select both object, then right-click to get context-menu.
                Boolean operations need two or more object, if select only one object, the menu will be always gray.
                • #23
                  just hit reply and click go advanced, then at bottom click manage attachments, attach the mp4 screen capture, or wmv
                  • #24
                    Hi VXChen, yes I understand and have followed all of these instructions to the letter- lassoing both items then right clicking to call down the menu.
                    I have also used Anton's suggestion of selecting the title first , then ctrl click the rectangle- The both show as two frames as per all your demo videos (thanks for those) but when I click the boolean call out- it is greyed out, even though the word "Boolean" isn't.
                    I have to solve this because the boolean solution is so elegant- far better than my chromakey route.
                    Rod
                    Rod Pike
                    • #25
                      which version vistitle?
                      the new 2.5 available since today is now compatible with 6.08 and is free for all 2.0 or later versions
                      • #26
                        Hi Anton, I'm v2.35- but the boolean process worked in this though surely? I have got something set wrong somewhere and will look appropriately stupid when it is found but I don't have a problem with that.
                        Thanks for the info on uploading- I followed the earlier guidance on that- but I have to admit that my problem is not knowing how to capture a screen video of what I am doing so that I can post it as you have.
                        Rod
                        Rod Pike
                        • #27
                          you can use Snagit (try it and if you like it, buy it)
                          • #28
                            Hi, here is a screenshot of the last stage of the menu selection- the Boolean choices are greyed out. Hope there is enough detail.
                            Rod
                            Rod Pike
                            • #29
                              can you attach the title file here
                              rename it to title.zip and attach
                              I then rename it back to title.vtlayout and see what is going on
                              • #30
                                Thanks Anton, I hope this has transferred OK
                                Rod
                                Rod Pike
