vistitle stencil effect on strapline
  • vistitle stencil effect on strapline
    hi, I want to lay a title over a video and have the video showing through the title. The title will lay on a coloured strapline. ( I do not want to encapsulate a video in the text, I can do that using the convert method in the bin described previously here.)
    My method has been to set the text in a colour (say green) and place it on a different coloured strapline rectangle (say grey). Then I place a full frame rectangle behind these, also in the green of the text.- then save.
    When pulling this title in to Edius I have then applied the chromakey filter and keyed out the green of the background and the text, allowing the video to show through the title. It works ,but I was wondering if there is an easier way- (newish to vistitle- have the manual but couldn't find an elegant method anywhere.)
    hanks for any input guys.
    Rod
    Rod Pike
    www.voxvideoproductions.co.nz
    A set of high quality paint brushes don't make you Rembrandt!
    Windows7-Edius 6.55-HDspark-VISTITLE v2.5.TMPGenc 5.vitascene v2-mercalli V2-Respeedr v1-Intel core i7 4770 8mb quad core processor-Asus Gryphon Z87 mobo- 16Gb ram-1 x samsung 256gb SSD 840 pro sata-2xWD 1tb sata caviar blue in raid 0-ASUS gtx 760 overclocked 2gb graphics card. Asus DRW 24 DVDRW DVD player-Cameras:Panasonic AC160A and AF102. and an 8kg cat who sleeps on my desk all day.
    is there a screenshot example to show what you mean exactly, then we can provide the vistitle steps
      I think attached picture is your wanted effect?
      1) Prepare a video file
      2) Prepare a title clip, it only have a text object, and have only a face property with pure white color
      3) In EDIUS bin, select video and title clip, then right click mouse, select "alpha matte" menu, composite the video and title clip to a new video
      4) Drag the new video to timeline
      5) Make a same title clip, but it only have a text object which have only a white color outline property, put this title overlay that new video
      6) Get the attached picture effect.
      Hope my steps is clear for you. :)
        hi Anton,
        yes I can recreate my test image- will have to look up best way to post- not sure on that, having never done it- any best guidelines? (sorry to be cheeky)
        cheers
        Rod
        Rod Pike
          Track Matte will put the video inside yout text very easily. Background goes on the bottom track, white title on the second track and video that you want inside the title on the top track. Apply Track Matte to the Keyer track of the top video clip.
            Hi again,
            VXchen, thanks for that but it is not quite what I am trying to do. Anton +GV, thankyou- I have not explained this very well have I. I will post a screenshot as soon as I can find out how to do it- searching the forum now, I know the info is there somewhere! Thanks for your continued help.
            Rod.
            Rod Pike
              I think the effect Rod is looking for is a title-generated "solid block" with "punched out" letters - it's a stencil like you would use for painting.
                Hi GV-BH- yes! that is pretty much it, but with the video playing full screen as the background- so looking through the letters, which are on a coloured band full width strapline in place of the cloud in your sample. Could you advise how to attach a screenshot of what I have please?
                Rod
                Rod Pike
                  Go Advanced, then click Manage Attachments to get the pop-up to attach a file.
                    Great! here goes. I have achieved this by using chromakey but it isn't the cleanest of results.
                    Rod
                    Rod Pike
                      Is this what your are looking to do?
                        Hi Jerry, yes exactly that. What was your method?
                        Rod
                        Rod Pike
                          Watch the video:
                          Vistitle cut out.wmv
                            Watch the video:
                            [ATTACH]9885[/ATTACH]
                            Yes, use Boolean operation of VisTitle !
                              See, I remember a lot of what you taught me :) Those NAB sessions we have are not wasted my friend!
