About VisTitle 2.5 installer
  • About VisTitle 2.5 installer
    Hi,
    We are so sorry for VisTitle 2.5 installer, we found it has some issues for EDIUS 32bit in some case.
    We will remove the downloading link temporary, and rebuild, upload new installer again as soon as possible.
    Regards.
    Beijing Videostar
    Is it okay for Edius 7?
      It is ok for Edius 7, we only found the issues for EDIUS 32bit (6.x) .
        Seems like the new installer is now available. Very quick work...excellent
          Well I now have a question about the install path for Vistitle 2.5
          I have downloaded the revised installer, but by default it wants to install to C\Vistitle. I have removed Vistitle 2.3.5, but that was installed in C\Program Files (x86).
          Does it matter if I install in the Program Files (x86) as before?
            No matter. You can install to any position.
              Thank you VXChen for the quick reply.
                Hello Mr. VXChen,
                Can we start the Vistitle install directly from the 2.50 version, or we must start from the 1.8xx version, and do all the updates.
                I work with Edius 7 and I own the 2.35 Vistitle version.
                Thanks for your help.
                Chabi
                FIRST SYSTEM: Supermicro X9DA7, Bi-Xeon E5 2665/2.40GHz, 16GB Kingston ecc, Zotac GTX680, Storm Mobile, Edius 6.55 & WG8, TMPGEnc Mastering Works 5 & Authoring Works 5, PluraEyes 2.0.3,, Vitascene V2 Pro, Mercalli V2 Pro, Vistitle 2.6, Neatvideo 3 & 4, Windows 7-64bit, Adobe Creative Suite CS6, Imaginate 2.0, Eizo CX 27", TV 32' "HD ready".
                Cameras: Panasonic AG-HPX250 & AG-AC90, Sony HVR-Z5, Canon EOS 5D Mark III.
                  2.5 is a full installer so you can just install that version
                    Thanks Adbear,
                    I did not know that. Installed very easily.
                    Chabi.
                      Yes, 2.5 will only have full installer. Uninstall the older VisTitle, then install this 2.5.
                      Because we use a new tool (install sheild) to build the installer, which cannot compatible with older tools (Inno setup), so we did not provide 2.5 update installer anymore.
