Vistitler 2.5 is out!
  • Vistitler 2.5 is out!
    Vistitler 2.5 is out for Edius 7 User's. it is almost 1 gb in size.
    Good to see they are using a faster server based in Germany. It only took 4 minutes to download nearly 1Gb.
    Does anyone know if you need to uninstall 2.3.5 first, or does this 2.5 overwrite earlier versions?
      it will uninstall any previous version
        This is a completely different installer. Directx installation is different as well.
        A lot more streamlined and sutomated.
          Well it didn't work for me. I went ahead and followed the instructions to install Vistitle 2.5. I am still using Edius 6.08.
          I now have 2 versions of Vistitle installed 2.3.5 and 2.5, both accessed as standalone, but nothing showing up in Edius. What now?
            you have to de-install previous versions first
            in this case you should now de-install both versions and do a new installation
            Eric
            English is not my native language
            ___________________________________
            System 1:Intel core i7-6700K 4 GHz - ASUS Z170-A - 32 GB DDR4 RAM - Intel HD 530 Graphic - Win 10 Pro - Storm 3G - Blu-Ray LG BH10LS30
            System 2: Intel i7-960 3,2 GHz - ASUS P6T - 12 GB DDR3 RAM - Radeon HD 5850 1GB - Win7 Ult 64bit SP1 - Storm 3G - Blu-Ray LG BH08LS20 - LG GH22NS50
              Eric
              Pity I didn't know that earlier. I have now uninstalled Vistitle 2.5, but when I uninstalled 2.3.5, it says that some elements were not removed and that I should do that manually.
              What elements do I look for?
                I'm using IOBituninstaller, it's showing you all conected elements
                The best uninstaller program: thoroughly uninstall and remove programs and delete apps on Windows. Force remove unwanted software with free uninstall tool. Fully support Windows 11.
                Eric
                  From the Vis site they semed to suggest an uninstall of a previous version first. Result Vistitle 2.5 installed but froze the whole computer when trying to usen in the latest flavour of Edius 6.54. I intend to upgrade to Edius 7 when Dave of DVC gets them in. Until then I will suffice with quicktitler. For me anyway Vistitle 2.5 and Edius 6.54 do not play well together.
                  E9 PRO ,Intensity Shuttle capture Nvidia 650 TI LG 3D Monitor HDMI Win 10 PRO 64 Bit.Vistitle 2.6, Robuskey. ASUS Z370 I7 8700 16 GB Hyper X black RAM 250GB 960 EVO. 2 ITB Disks
                    If you are running AV software make sure to exclude Vistitle 2.5 and related elements. Turn off AV for installation.
                      I have now installed Vistitle 2.5.
                      Edius 6.08 opens much slower than before and opening Vistitle is also slower.
                      Is this normaL?
                      I've also noticed that when I close Edius, it still appears in Task Manager/ Processes as still running. I have to manually end the process if I want to open Edius again.
                        that is not normal
                        uninstall it again and manually delete the Vistitle folder on the C drive, then also make sure all vistitle plugins are gone from the EDIUS plugins folder
                        look for VEDIUSImporter
                          I just wanted to point to some free tutorials on Vistitle on Youtube, made by David in the UK:
                          David Clarke runs training course on Adobe Premiere Pro, Grass Valley EDIUS, DaVinci Resolve and Avid Media Composer. On this channel you will see various training videos on these an other effects programs.
                          I think they are great, and there is some other great stuff there too, imo :)
                          Ulf
                          Best regards * Ulf * Denmark
                          mail to me
                            Just installed Vistitle v2.5.0.0 without a hitch. All seems OK as a plug-in and stand alone. Looking forward to using it now.
                            i7 3930K, Win 10 pro 64 Bit.
                            RAM 32 GB.
                            ASUS P9X79-Deluxe.
                            PS Thermaltake 1kW.
                            Graphics Gigabyte GTX1660 OC.
                              Is this normaL?
                              I have trouble using 2.5.0 in Edius 6.54
                              I have tried to install it two times, with uninstall and CCleaner in between, and it is not running good. Edius stops half way through the progress indicator for startup for 20-30 sec. and then the "edius watchdog" screen asking if I want to exit or make a report. Edius starts up in the background though, but Vistitle is very slow.
                              The standalone application works fine.
                              I downgraded to 2.35 and all is fine.
                              I installed 2.5.0 on Edius 7 (on another box though) without any hickups.
                              Have not tried to investigate further now, because I will upgrade to 7 "for real" as soon as I get my disc.
                              Ulf
                              mail to me
