Adding New Blue Noise Reduction Stops Preview from Running
  • Adding New Blue Noise Reduction Stops Preview from Running
    I have Edius 6.08. Just purchased New Blue Essentials II today. Added Noise reduction to a 1-1/2 hour long clip and when it is not activated, the preview window displays fine. When I activate the plugin, the preview window stops completely. Have used the New Blue sharpen filter with no problem.
    Computer: Zeon 6-core, nVidia Quadro 4000 video card, 16 gigs ram.
    Thanks for your help.
    Alan
    The noise reduction plugin works absolutely fine in Sony Vegas.
    Does anyone use this plugin?
      Do you have the latest nvidia drivers?
        Yes, just installed them two days ago, in addition to many other computer updates.
        I sent a support request to New Blue and this was their response:
        My email:
        "Just purchased your Essentials II package. In Edius 6.08, the preview window stops when I add noise reduction. I have Windows 7 and a new Zeon 6-core computer with 18 gigs of ram. Thanks...Alan"
        Their response:
        "What do you mean by "stops". It may take a little time for each frame to draw. I certainly will not be "real time". That is probably the most intensive effect we have and it does take some time to process the entire frame. You might try pre-rendering that section and then it should playback smoothly."
        How can one use the Edius preview window with a noise reduction plugin without being able to see the results? By real time, I mean just watch the video run in the preview window. If I want to make tweaks to the plugin setting, I would like to see the results play in the preview window.
        I'm confused with their response.
        I know it will certainly take longer to render the video but I just want to see the results before I render.
        Thanks...Alan
          Got a response back from New Blue.
          "Do all your adjustments looking at a single frame. Then pre-render that clip and the preview will be smooth."
          I googled the term pre-render, searched on this site for "pre-render."
          How do you pre-render in Edius 6? Searched the manual and found nothing.
          Thanks...Alan
            Hold Shift and then Spacebar
              Place in/out on the area required and press ahift + Q this will place a new clip above which will then play RT
                Thanks for all the help.
                I love this forum.
                It takes 7 minutes to render 20 seconds of video for preview.
                I'm using a Dell Precision T3600, Xeon 2650 6-core processor 3.2 GHz with hyper threading. Edius sees 12 processors when I boot up.
                Just for comparison, does using Neat Image with newer versions of Edius take a similar amount of time to render video?
                With my 1-1/2 hour video it is projected to take 44 hours to render.
                  Why would you want to render the whole 1.5 hours ?
                    The timeline consists of AVI clips my daughter shot when she was young while playing in the basement, one with not much light.
                    I figured I would apply noise reduction to the entire timeline.
                    In Sony Vegas, using the New Blue plugin I had no problems with the preview window or rendering in a reasonable amount of time.
                    I normally do not use Vegas but since the plugin installs in both software packages, I chose to render the AVI files in Vegas thinking the plugin was not working at all in Edius.
                    Now I know it works, just really, really, slow.
                    Should have downloaded a trial first.
                    Alan
                      from memory, the newblue filters have an enable GPU option, then it will render way faster
                      can you check if it is enabled
                        Do you have any idea where I would check for this?
                          from memory, you click the ?
                          if you can't find it, I will boot from 6.54 and check
                            its under th i button
                            but i have found on most occassions disasbling gpu gives better performance
                              Well, for me, it was money I wish I had not spent. I had Neat Video and Vegas 8.0.
                              Converted some old AVI footage from the Vegas timeline, added some Neat Video, and burned with Edius.
                              Outcome was fine.
