Edius 6.54 Render Crashes New Blue
    I reported problems with KB2670838 back in March
    http://forum.grassvalley.com/forum/s...ight=KB2670838
      the following 6 updates will never be installed in any Win7 PC I build
        More stuff NewBlue GPU switched on crashes Edius 6.54
        One last go at it.....
        Its still somewhat confusing because I have a Clevo i7 950 D900F laptop with an Nvidia 280M chip with the native display at 1920 by 1200. The Nvidia driver for this is exactly the same as the HP Z800 with two Nvidia FX3800 cards. Driver 320.49
        Firstly there isn't a problem when rendering at all with the laptop with NewBlue GPU acceleration turned on. So this is strange as the desktop is in comparison so fussy.
        NewBlue Builds are mostly 130227 & 8. Later build tests seem to make matters worse.
        I have done a Windows update compare list and the laptop and the desktop have an equivalent list.
        Before altering anything without the GPU acceleration switched on on the desktop NewBlue effects render ok. With them on the render did not complete and Edius crashed.
        The next step was to do some research with the Open GL GPU rendering on the web. There were suggestions about GPU response delays as I did find adding TDR values helped in the registry and rebooting.
        This was after crashing out the GPU driver by twiddling the knobs too fast in NewBlue control panels it led me to look in this direction.
        TdrDdiDelay = 50(D)
        TdrDelay = 60 (D)
        TdrLevel = 0
        Now we have render with GPU on in NewBlue completes and the first play through in Edius works. The second play through reveals the buffer running down to 1 and freezing Edius.
        If we now restart Edius and set the buffer down to 128MBytes now rendering a Newblue filter and playback works.
        I hope these findings are useful to somebody.
        That is about the limit of software knobs and buttons I can think of tweaking.
        I am in pause mode for Edius 7 as although ProDad are up to date with 64Bit Plugins (well done them) for Edius Boris Red and NewBlue aren't yet.
