Paint Program For Edius 5
  • Paint Program For Edius 5
    I have been using Boris Red for doing some Paint/Clone touch ups on footage in Edius 6.54
    But I keep getting crashes.
    Is there another program that is simple to use that can paint/Clone on to footage to say "fill in a gap in a door" with a colour, that sort of thing?
    Mark Twittey
    Walkabout TV
    Edit 1: Custom Built 3XS System, Dual Boot WinXP Pro 32bit/ Win7 Pro 64-bit,
    Asus P6T Deluxe Motherboard, Intel I7 2.66GHz CPU, Nvida GeForce GTX 580 card, LSI Raid controller,
    5Tb WD drives, 12Gb DDR3 Corsair memory, 2 x 27" ASUS LED's, Edius 7.4 & Liquid XE, Boris RED 5.4.0.378, Vistitle 2.5. New Blue Video Est.III
    If you are getting crashes, there is something wrong. Which version of Boris Red
    are you using? I have Boris Red and do not get any crashes.
      Boris RED 5.2.2.409
      Edius 6.54
      I have always had problems with all versions of Edius.
      Mark Twittey
      Walkabout TV
        in Boris preferences, disable Open GL
          In some systems Open GL does play havoc with stability. I would turn it off, as Anton suggested, just to be on the safe side.
            Thanks guys I will turn off open GL and see if it improves
            Mark Twittey
            Walkabout TV
              May I suggest a combination of the Mask and Chrominance filters?
              Pretty easy for color replacement and rock stable!
