Newblue Titler pro/Realtime
  • Newblue Titler pro/Realtime
    I am trying to get through a project in Titler pro the lack of RT is killing me. How do I prerender the titles? Will I keep my alpha channels?
    Randy
    If you have 6.5x it is easy. You can do shif+G or export them to HQ +alpha.
      Is there a way to batch them?
      Randy
        Sure for for export add them to the batch exporter.
          When I re render I lose the alpha channel
          Randy
            Is your project set to alpha?
            Is your render Codec HQX
            Are you using shift+G
              Checked and it works perfect with Both HQ and HQX. Only possible in 6.5x
                Not 6.0 huh? ok
                Randy
                  Come on check post number 2 and 7.
                    ok if im doing it right 1. right click and select convert then export the title out. I have alpha but the title inside the outline is keyed out too. So its unusable.
                    Randy
                      If you are using 6.5x it works fine if you don't have 6.5 it is a bit pointless to keep reporting. Full alpha is a new feature in 6.5 .
                      Select the file export to Hq with alpha done.
                      select file shift + q and done.
                        well thats what I said before your"Come on check post number 2 and 7" like im a idiot post. I only have 6.0 i'll just get through this project and get a new titler later.
                        Randy
