transition from Boris RED 5 to Edius
  • transition from Boris RED 5 to Edius
    hello
    I am tying to transfer some transition from Boris RED 5 to Edius, is someone knows how it is possible.
    i installed Boris RED 5 and I thought folder' s transition from boris will be available on Edius panel like Vitascene but it is not
    how can I do it ?
    Sony CCD-TRV48E PAL+ADVC110, Sony DCR HC90E, Sony HDR CX360VE,Gopro Black Edition 4Kp
    This is a very speedy tutorial to get you running. I did not have my transition selections animated. But, it pretty much shows you how to use it.
    Boris Transitions.wmv
      Originally posted by ggdn View Post
      hello
      how can I do it ?
      Which version of Edius?
      Yes there should be a Boris folder in both Video Filters and Transitions
      When you installed Boris did you select the correct version of Edius to install to?
      Is Boris avaialable in the Video filters section?
      Barry
        This folder does not appear on my effects folder, that the one I would like to know how to make it available on Edius
        Barry
        Which version of Edius? Edius 6.02
        When you installed Boris did you select the correct version of Edius to install to? Boris did not ask me about Edius, and Edius was already installed when I have installed Edius
        Boris is not avaialable in filters section
          Barry
          Think I know what happened, when you installed Boris you did not select "Custom" Install
          Unless you chose this the Host selection does not appear and just installs the stand alone version
          Re install and select custom, and the following screen should appear
          I have also added a copy of what should appear in the GV/Edius 6/Plugin directory
          Best of luck
          Re EDIT WOOPS got the version the wrong way around on the picture, DAH
          Barry
          Last edited by Bluetongue; 06-05-2013, 08:48 AM. Reason: Mistake in Install picture
            yes! you totaly right, because I remember that when I installed boris, custom installation was set by default, and changed for full installation so, boris did not showed me panel to select edius version that why plugins have not been installed
            so will uninstall Boris this evening and install it folowing default settings then I will be able to select Edius version
            many thanks I will keep you inform
              done
